StarTech.com 3ft Right Angle Micro-USB Cable
Quicklinx: BL6WWS00 Mfr#: USB2AUB2RA1M
Length: 1m
Select:
Hurry, only 2 left in stock!
£5.11 ex VAT
£6.13 inc VAT
Charge and sync your Micro-USB device from a hard-to-reach USB port. This Micro-USB cable features two right-angled connectors that let you connect to hard-to-reach ports and also help prevent cable and port damage. The cable is great for charging your mobile devices in a car, or for connecting to peripherals that may be difficult to connect to when using a straight connection.
The right-angled connectors allow you to connect to ports that may otherwise be inaccessible or difficult to reach. Perfect for charging car-mounted mobile devices or for connecting your portable hard drive or other Micro-USB 2.0 device to your computer in such a way that it fits your installation needs.
The angled connectors prevent the cable from bending awkwardly or from straining too much to make a connection. It offers a more natural fit at the connection points, preventing unnecessary stress and damage to the cable and ports.
Replace the cable that came with your Micro USB mobile device, or keep one as a spare while traveling so that your mobile devices will be ready to use while you're on the road.
The cable features a thin, yet sturdy connector molding, so you'll be able to connect to your phone or tablet without removing its protective case. Plus, the cable's right-angled Micro-USB connector lets you text, work or game on your mobile device even while it's charging, without the cable getting in the way.
  • Convenient design
    The right-angled connectors on this cable allow for easy connections in confined spaces, preventing strain on device ports and enhancing longevity.
  • Reliable standards
    This cable meets USB 2.0 standards, ensuring efficient data transfer and charging speeds for compatible devices.
  • Durable connectors
    With nickel-plated connectors, this cable offers improved conductivity and resistance to corrosion, promising longevity.
StarTech.com 1m 3 ft Micro-USB Cable with Right-Angled Connectors - M/M - USB A to Micro B Cable - 3ft Right Angle Micro USB Cable (USB2AUB2RA1M) - USB cable - Micro-USB Type B to USB - 1 m
USB cable
Right-angled connector
Length
1 m
Connector
5 pin Micro-USB Type B - male
Connector (Second End)
4 pin USB Type A - male
USB / USB 2.0
P/N: USB2PCARBK, USB2PCARBKS, USBEXTAA10BK, USBEXTAA3BK, USBEXTAA6BK, USBLT2PCARW, USBUB2PCARB
USB cable
American Wire Gauge (AWG)
24/30
Plated Connector
Nickel
Length
1 m
Connector
USB / USB 2.0, RoHS
BL6W StarTech.com 6in Micro USB Cable - A to Micro B In Stock £4.66
BL6W StarTech.com 3ft Right Angle Micro-USB Cable In Stock £5.11
BL6W StarTech.com 6ft Right Angle Micro-USB Cable In Stock £6.17
Length: 1m
