StarTech.com 3ft DP to HDMI cable - 4K
Quicklinx: B90PWS00 Mfr#: DP2HDMM1MB
More than 50 in stock
£13.90 ex VAT
£16.68 inc VAT
Eliminate clutter by connecting your PC directly to an HDMI display using this short cable. This 3-foot DisplayPort to HDMI adapter cable lets you connect your DisplayPort equipped Ultrabook, laptop or desktop computer to an HDMI television, monitor or projector with no additional adapters or cables required. The passive adapter supports video resolutions up to Ultra HD 4K.
This adapter cable ensures you can maintain an astonishing picture quality, four times the resolution of 1080p, when converting DisplayPort to HDMI. The adapter is also backward compatible with lower resolution displays and video sources. With support for high-definition resolutions of 1080p and 720p, you can future-proof your existing setup for 4K video.
For the simplest and most discreet installation, this DP to HDMI adapter connects directly from your DisplayPort video source to the HDMI port on your display. It doesn't need a power source, unlike some converter dongles that require active power and separate bulky video cabling.
At 3ft in length, this adapter cable delivers a compact connection that eliminates excess to ensure a tidy, professional installation. For longer installations, StarTech.com also offers a 6 ft DP to HDMI cable (DP2HDMM2MB), enabling you to choose the right cable length for your custom installation needs.
  • Astonishing picture quality
    Thisadapter cable ensures you canmaintainan astonishing picture quality, fourtimes the resolution of 1080p, when converting DisplayPortto HDMI.The adapter is also backwardcompatible with lower resolution displays and video sources.With support forhigh-definition resolutions of 1080p and 720p, youcan future-proof your existing setup for 4K video.
  • Hassle-free setup
    For the simplest and most discreet installation,this DP to HDMI adapter connects directly from your DisplayPort video source tothe HDMI port on your display.Itdoesn't need apower source,unlike someconverter dongles that require active powerand separate bulky videocabling.
StarTech.com 3 ft (1 m) DisplayPort to HDMI Adapter Cable - 4K DisplayPort to HDMI Converter Cable - Computer Monitor Cable (DP2HDMM1MB) - video cable - 1 m
Cable
Video cable - DisplayPort / HDMI
Length
1 m
Connector
DisplayPort - male
Connector (Second End)
HDMI - male
DisplayPort 1.2
4K support
3-year warranty
P/N: TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE
Cable Type
Video cable 4K support
Interface Supported
DisplayPort / HDMI
DisplayPort 1.2
Length
1 m
HDCP compliant, DPCP compliant
Connector
20 pin DisplayPort - male
19 pin HDMI Type A - male
FCC, RoHS
Limited warranty - 3 years
B90P StarTech.com 3ft DP to HDMI cable - 4K In Stock £13.90
B90P StarTech.com 3 ft mDP to HDMI cable - 4K In Stock £12.97
B90P StarTech.com 6ft mDP to HDMI cable - 4K In Stock £15.26
B90P StarTech.com 6 ft DP to HDMI cable - 4K In Stock £15.82
B90P StarTech.com 3ft mDP to HDMI cable - 4K In Stock £12.97
Stock Status: In stock
