StarTech.com 3ft DP to DVI Converter Cable
Quicklinx: BFP9WS00 Mfr#: DP2DVI2MM3
Length: 91.4cm
36 In Stock
£14.62 ex VAT
£17.54 inc VAT
Eliminate clutter by connecting your PC directly to the monitor using this short adapter cable. This 3-foot DisplayPort to DVI-D adapter cable lets you connect your DisplayPort (DP) equipped Ultrabook, laptop or desktop computer to a DVI monitor or projector with no additional adapters or cables required. The passive adapter supports video resolutions up to 1920x1200 (WUXGA), perfect for high-resolution applications.
For the simplest and most discreet installation, this DP to DVI-D adapter connects directly from your DisplayPort video source to the DVI port on your display. It doesn't need a power source, unlike some converter dongles that require active power and separate bulky video cabling.
With this DP to DVI cable, you can bridge the gap between old and new technologies by converting your existing DVI display to work with your DP video source.
Upgrading every component in your A/V setup can be costly and time consuming. This cost-effective adapter lets you save the expense and hassle of buying a new display, by ensuring your existing DVI display will work with your DisplayPort equipment.
This 3 ft. adapter cable delivers a compact connection that eliminates excess to ensure a tidy, professional installation. For longer installations, StarTech.com also offers a DP2DVIMM6 6 ft DP to DVI cable (DP2DVIMM6), enabling you to choose the right cable length for your custom installation needs.
  • Reliable connection
    This DisplayPort to DVI Converter Cable allows seamless connectivity between DisplayPort devices and DVI displays, providing a straightforward solution for various setups.
  • High-quality signal
    With its gold-plated connectors, this cable minimizes signal loss and ensures consistent performance, delivering impressive video quality for your presentations and media consumption.
  • Durable construction
    The PVC shielding on the cable protects it from electromagnetic interference, ensuring a clear and stable connection during use in different environments.
  • Wide resolution support
    This converter cable supports resolutions up to 1920 x 1200, making it suitable for different applications, from everyday tasks to high-resolution multimedia displays.
  • Compliance assured
    Meeting FCC, RoHS, and RCM standards, this product is safe for use and environmentally friendly, promising a quality experience and peace of mind.
StarTech.com DisplayPort to DVI Converter Cable - DP to DVI Adapter - 3ft - 1920x1200 (DP2DVI2MM3) - display cable - 91.4 cm
Display cable
Length
91.4 cm
Connector
DisplayPort - male
Connector (Second End)
DVI-D - male
FCC, RoHS, RCM
3-year warranty
P/N: DK30CH2DEP, DK30CH2DEPUE
Display cable
Shielding Material
PVC
Plated Connector
Gold
Length
91.4 cm
Connector
20 pin DisplayPort - male
24+1 pin digital DVI - male
DisplayPort++, FCC, RoHS, RCM
3-year warranty
BFP9 StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £8.48
BFP9 StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £21.80
BFP9 StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M In Stock £22.37
BFP9 StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £9.22
BFP9 StarTech.com 6 ft DisplayPort to DVI Cable - M/M In Stock £5.53
BFP9 StarTech.com DisplayPort to DVI Active Adapter In Stock £21.34
BFP9 StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female In Stock £9.71
BFP9 StarTech.com DisplayPort to DVI Dual Link Active Video Adapter Converter - DP to DVI-D - 2560x1600 In Stock £41.39
BFP9 StarTech.com 3 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black In Stock £18.76
BFP9 StarTech.com 3ft DP to DVI Converter Cable In Stock £14.62
Length: 91.4cm
