StarTech.com 3ft DisplayPort Panel Mount Cable - F/M
Quicklinx: 6PDQWS00 Mfr#: DPPNLFM3
20 in stock
£11.08 ex VAT
£13.29 inc VAT
This 3ft panel mount DisplayPort cable features a DisplayPort male connector on one end, and a DisplayPort panel mount (female) molded connector on the other, providing a well-secured, easy to access DisplayPort connection on any machine port or faceplate.
StarTech.com 3ft DisplayPort Panel Mount Cable - F/M - DisplayPort cable - 91.4 cm
DisplayPort cable
Latched, molded
Length
91.4 cm
Connector
DisplayPort - male
Connector (Second End)
DisplayPort - female
RoHS, NEC-CMG
P/N: DP2MDPMF6IN
DisplayPort cable
American Wire Gauge (AWG)
28
Latched, molded
Length
91.4 cm
Connector
20 pin DisplayPort - male
20 pin DisplayPort - female
RoHS, NEC-CMG
P/N: DP2MDPMF6IN
6PDQ StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £10.00
6PDQ StarTech.com 6 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £7.30
6PDQ StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £15.85
6PDQ StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F In Stock £10.93
6PDQ StarTech.com 25 ft DisplayPort Cable with Latches - M/M In Stock £46.72
6PDQ StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £33.00
6PDQ StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M In Stock £26.71
6PDQ StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £22.13
6PDQ StarTech.com 3ft DisplayPort Panel Mount Cable - F/M In Stock £11.08
6PDQ StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.69
Price Range Ex VAT: 0 - 50
