This 3ft panel mount DisplayPort cable features a DisplayPort male connector on one end, and a DisplayPort panel mount (female) molded connector on the other, providing a well-secured, easy to access DisplayPort connection on any machine port or faceplate.
- StarTech.com 3 ft. (0.9 m) Displayport Male to Female Cable - Mounting - Latched Connectors - DisplayPort - DP Monitor Cable (DPPNLFM3) - DisplayPort cable - 91.4 cm
- DisplayPort cable
- Latched, molded
- Length
- 91.4 cm
- Connector
- DisplayPort - male
- Connector (Second End)
- DisplayPort - female
- RoHS, NEC-CMG
- Black
- Limited lifetime warranty
- Designed For
- P/N: CDP2DP141MB, CDP2DP146B, CDP2DPMM1MB, CDP2DPMM6B, DISPL1M, DISPL2M, DISPL3M, DISPL50CM, DISPL5M, DISPLPORT10L, DISPLPORT15L, DISPLPORT1L, DISPLPORT20L, DISPLPORT30L, DISPLPORT3L, DISPLPORT6L, DP2MDPMF3, DP2MDPMF6IN, DP4N1USB6, MDP2DPMM10, MDP2DPMM3, MDP2DPMM6, MDP2DVIMM6BS
- DisplayPort cable
- American Wire Gauge (AWG)
- 28
- Latched, molded
- Length
- 91.4 cm
- Black
- Connector
- 20 pin DisplayPort - male
- 20 pin DisplayPort - female
- RoHS, NEC-CMG
- Designed For
StarTech.com DisplayPort to HDMI Video Adapter Converter | In Stock | £12.77 |
StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F | In Stock | £11.52 |
StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M | In Stock | £22.12 |
StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M | In Stock | £24.08 |
StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £24.00 |
StarTech.com 1 ft Panel Mount USB Cable A to A - F/M | In Stock | £4.94 |
StarTech.com 1 ft Panel Mount USB Cable - USB A to Motherboard Header Cable F/F | In Stock | £5.49 |
StarTech.com 1 ft Panel Mount USB Cable B to B - F/M | In Stock | £6.59 |
StarTech.com 3ft DisplayPort Panel Mount Cable - F/M | In Stock | £13.14 |
StarTech.com 3 ft Standard HDMI Cable for Panel Mount - F/M | In Stock | £9.49 |
StarTech.com 3 ft 20 pin DisplayPort Extension Panel Mount Cable - M/F | In Stock | £17.51 |
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £14.12 |
StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £12.26 |
