This 3ft panel mount DisplayPort cable features a DisplayPort male connector on one end, and a DisplayPort panel mount (female) molded connector on the other, providing a well-secured, easy to access DisplayPort connection on any machine port or faceplate.
Durable construction
The cable features molded connectors that enhance durability, making it less prone to damage and suitable for frequent use while maintaining a reliable connection. -
Secure connection
Latched connectors ensure a secure fit between devices, preventing accidental disconnections and ensuring stable video transmission. -
Versatile compatibility
This DisplayPort cable can effectively connect a variety of devices featuring DisplayPort connections, making it suitable for monitors, projectors, and computers. -
Effective transmission
With a 28 AWG wire gauge, this cable supports effective data transmission, delivering high-quality video signals to your display without loss of quality. -
Environmentally compliant
This product meets RoHS standards, ensuring adherence to regulations for harmful substances, making it an environmentally responsible choice.
- StarTech.com 3 ft. (0.9 m) Displayport Male to Female Cable - Mounting - Latched Connectors - DisplayPort - DP Monitor Cable (DPPNLFM3) - DisplayPort cable - 91.4 cm
- DisplayPort cable
- Latched, molded
- Length
- 91.4 cm
- Connector
- DisplayPort - male
- Connector (Second End)
- DisplayPort - female
- RoHS, NEC-CMG
- Black
- Limited lifetime warranty
- Designed For
- P/N: CDP2DP141MB, CDP2DP146B, CDP2DPMM1MB, CDP2DPMM6B, DISPL1M, DISPL2M, DISPL3M, DISPL50CM, DISPL5M, DISPLPORT10L, DISPLPORT15L, DISPLPORT1L, DISPLPORT20L, DISPLPORT30L, DISPLPORT3L, DISPLPORT6L, DP2MDPMF3, DP2MDPMF6IN, DP4N1USB6, MDP2DPMM10, MDP2DPMM3, MDP2DPMM6, MDP2DVIMM6BS
- DisplayPort cable
- American Wire Gauge (AWG)
- 28
- Latched, molded
- Length
- 91.4 cm
- Black
- Connector
- 20 pin DisplayPort - male
- 20 pin DisplayPort - female
- RoHS, NEC-CMG
- Designed For
StarTech.com DisplayPort to HDMI Video Adapter Converter | In Stock | £11.74 |
StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F | In Stock | £10.80 |
StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M | In Stock | £21.26 |
StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £20.93 |
StarTech.com 1 ft Panel Mount USB Cable A to A - F/M | In Stock | £4.93 |
StarTech.com 1 ft Panel Mount USB Cable - USB A to Motherboard Header Cable F/F | In Stock | £5.94 |
StarTech.com 1 ft Panel Mount USB Cable B to B - F/M | In Stock | £5.67 |
StarTech.com 3ft DisplayPort Panel Mount Cable - F/M | In Stock | £13.69 |
StarTech.com 3 ft Standard HDMI Cable for Panel Mount - F/M | In Stock | £9.35 |
StarTech.com 3 ft 20 pin DisplayPort Extension Panel Mount Cable - M/F | In Stock | £15.06 |
StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £11.55 |
