StarTech.com 3ft DisplayPort Panel Mount Cable - F/M
Quicklinx: 6PDQWS00 Mfr#: DPPNLFM3
20 In Stock
£14.74 ex VAT
£17.68 inc VAT
This 3ft panel mount DisplayPort cable features a DisplayPort male connector on one end, and a DisplayPort panel mount (female) molded connector on the other, providing a well-secured, easy to access DisplayPort connection on any machine port or faceplate.
  • Durable construction
    The cable features molded connectors that enhance durability, making it less prone to damage and suitable for frequent use while maintaining a reliable connection.
  • Secure connection
    Latched connectors ensure a secure fit between devices, preventing accidental disconnections and ensuring stable video transmission.
  • Versatile compatibility
    This DisplayPort cable can effectively connect a variety of devices featuring DisplayPort connections, making it suitable for monitors, projectors, and computers.
  • Effective transmission
    With a 28 AWG wire gauge, this cable supports effective data transmission, delivering high-quality video signals to your display without loss of quality.
  • Environmentally compliant
    This product meets RoHS standards, ensuring adherence to regulations for harmful substances, making it an environmentally responsible choice.
StarTech.com 3 ft. (0.9 m) Displayport Male to Female Cable - Mounting - Latched Connectors - DisplayPort - DP Monitor Cable (DPPNLFM3) - DisplayPort cable - 91.4 cm
DisplayPort cable
Latched, molded
Length
91.4 cm
Connector
DisplayPort - male
Connector (Second End)
DisplayPort - female
RoHS, NEC-CMG
P/N: CDP2DP141MB, CDP2DP146B, CDP2DPMM1MB, CDP2DPMM6B, DISPL1M, DISPL2M, DISPL3M, DISPL50CM, DISPL5M, DISPLPORT10L, DISPLPORT15L, DISPLPORT1L, DISPLPORT20L, DISPLPORT30L, DISPLPORT3L, DISPLPORT6L, DP2MDPMF3, DP2MDPMF6IN, DP4N1USB6, MDP2DPMM10, MDP2DPMM3, MDP2DPMM6, MDP2DVIMM6BS
DisplayPort cable
American Wire Gauge (AWG)
28
Latched, molded
Length
91.4 cm
Connector
20 pin DisplayPort - male
20 pin DisplayPort - female
RoHS, NEC-CMG
6PDQ StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £11.80
6PDQ StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F In Stock £10.81
6PDQ StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £22.80
6PDQ StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M In Stock £22.37
6PDQ StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £17.58
6PDQ StarTech.com 1 ft Panel Mount USB Cable A to A - F/M In Stock £5.29
6PDQ StarTech.com 1 ft Panel Mount USB Cable - USB A to Motherboard Header Cable F/F In Stock £5.99
6PDQ StarTech.com 3ft DisplayPort Panel Mount Cable - F/M In Stock £14.74
6PDQ StarTech.com 3 ft Standard HDMI Cable for Panel Mount - F/M In Stock £9.20
6PDQ StarTech.com 3 ft 20 pin DisplayPort Extension Panel Mount Cable - M/F In Stock £15.45
6PDQ StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.58
6PDQ StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £13.66
