8K: enabling business continuity
8K has a resolution of 7680 x 4320 and is also known as 4320p and Ultra High Definition (UHD). Suitable for digital signage and other commercial displays that require the highest available resolution. This cable is backward compatible with 4K and 5K displays making it the perfect peripheral to start future proofing your cabling infrastructure. -
Comprehensive?product testing?and?expert?technical support
StarTech.com?conducts thorough?compatibility and performance?testing?on?all?the products?to?ensure they are meeting or?exceeding industry standards?and providing?high-quality products to the customers. Their?local?StarTech.com?Technical?Advisors?have a broad product expertise?and?work directly with StarTech.com?Engineers to?provide support for the customers?both pre- and post-sales.
- StarTech.com 3ft (1m) VESA Certified DisplayPort 1.4 Cable, 8K 60Hz HDR10, Ultra HD 4K 120Hz DP Video Cable, DisplayPort to DisplayPort Cable, DP Cord for Monitors/Displays, M/M - DP 1.4 Cable with Latches (DP14VMM1M) - DisplayPort cable - DisplayPort to DisplayPort - 1 m
- DisplayPort cable
- Technology
- Shielded
- Molded, passive cable, 8K60Hz (7680 x 4320) support, 4K120Hz (3840 x 2160) support, strain relief, HBR3 support, Display Stream Compression 1.2 (DSC), DisplayPort Multi-Stream Transport (MST), 32 audio channels, HDR10 support, 7.1 audio channel support, Chroma subsampling (4:4:4), 32.4 Gbps data rate, Forward Error Correction, 5.1 audio channel support
- Length
- 1 m
- Connector
- 20 pin DisplayPort - male
- Connector (Second End)
- DisplayPort 1.4
- Grey, black
- Limited lifetime warranty
- DisplayPort cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- Thermoplastic elastomer (TPE)
- American Wire Gauge (AWG)
- 34
- Plated Connector
- Gold
- Length
- 1 m
- Outside Diameter
- 4.5 mm
- Grey, black
- Connector
- DisplayPort 1.4, RoHS, HDCP 2.2, 8K VESA certified
- Shipping Width
- 22 cm
- Shipping Depth
- 20 cm
- Shipping Height
- 2 cm
- Shipping Weight
- 59 g
StarTech.com VESA-Certified DP 2.1 Cable | In Stock | £14.34 |
StarTech.com VESA-Certified DP 2.1 Cable | In Stock | £14.08 |
StarTech.com VESA-Certified DP 2.1 Cable | In Stock | £20.29 |
