3ft (1m) DB9 to 3.5mm Serial Cable for Serial Device Configuration, RS232 DB9 Male to 3.5mm Cable for Calibrating Projectors, Digital Signage, and/or TVs via Audio Jack - Al-Mylar EMI Shielding (9M351M-RS232-CABLE).
Reliable shielding technology
The aluminum mylar shielding material protects the cable from external interference, ensuring stable and uninterrupted data transmission. -
Secure connection design
With molded connectors and thumbscrews, the cable provides a reliable connection that reduces the risk of accidental disconnections during use. -
Environmentally compliant
This cable meets RoHS and WEEE standards, ensuring that it is safe for the environment while delivering high-quality performance. -
Durable construction
The PVC jacket and strain relief design protect the cable while enhancing longevity, making it suitable for various applications.
- StarTech.com 3ft (1m) DB9 to 3.5mm Serial Cable for Serial Device Configuration, RS232 DB9 Male to 3.5mm Cable for Calibrating Projectors, Digital Signage, and/or TVs via Audio Jack - Al-Mylar EMI Shielding (9M351M-RS232-CABLE) - serial cable - DB-9 to mini-phone stereo 3.5 mm - 1 m
- Serial cable
- Technology
- Shielded
- Molded, thumbscrews, strain relief, EMI protection
- Length
- 1 m
- Connector
- 9 pin D-Sub (DB-9) - male
- Connector (Second End)
- Mini-phone stereo 3.5 mm - male
- Black
- Limited lifetime warranty
- Serial cable
- Technology
- Shielded
- Shielding Material
- Aluminium mylar
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Length
- 1 m
- Outside Diameter
- 3.5 mm
- Black
- Connector
- RoHS, EMI, WEEE
- Shipping Width
- 22 cm
- Shipping Depth
- 12 cm
- Shipping Height
- 1 cm
- Shipping Weight
- 23 g
StarTech.com Slimline DB9 Serial Gender Changer - F/F | In Stock | £4.74 |
StarTech.com UCB C to Serial Adapter | In Stock | £16.64 |
StarTech.com USB to Serial Cable - Win/Mac | In Stock | £15.93 |
