StarTech.com 3ft/1m USB to Serial Cable
Quicklinx: HKKLWS00 Mfr#: 1P3FFCB-USB-SERIAL
Length: 1m
25 In Stock
£30.87 ex VAT
£37.04 inc VAT
Add RS-232 serial communication support to USB-A enabled Data Terminal Equipment (DTE - e.g., desktop or laptop), using this 3.3ft (1m) straight through USB to Serial Adapter Cable.
  • Serial Port Expansion
    The USB Serial Adapter adds an RS-232 serial DB/DE-9 (male) connector to a desktop or laptop via a USB Type-A port. Secure the adapter to a serial device, using pre-installed and removable slotted D-Sub thumbscrews or install the included DB-9 Nuts for compatibility with other serial peripheral devices or cables.
  • LED Indicators
    Data transmission and reception LED indicators on the adapter provide real-time monitoring of port activity. The USB LED indicates when the adapter has successfully enumerated on the desktop or laptop. All the LEDs aid with diagnostics and troubleshooting.
  • Seamless Connectivity
    The adapter is compatible with Windows, macOS, ChromeOS, and Linux. Drivers automatically install to Windows 7 and newer versions and macOS 10.15 and above. The USB to RS-232 adapter features COM retention, which automatically reassigns the COM port value if the cable is disconnected and reconnected, or if the system is rebooted.
  • Built To Last
    The rugged TPE construction and Level-4 ESD protection (15kV air and 8kV contact) enhance the reliability and longevity of the USB to Serial Adapter. Copper shielding minimizes Electromagnetic and Radio Frequency Interference (EMI and RFI). Gold-plated connectors enhance signal conductivity.
StarTech.com 3ft (1m) USB to Serial Adapter Cable, Interchangeable DB9 Screws/Nuts, COM Retention, USB-A to DB9 RS232, FTDI IC, Level-4 ESD Protection, Windows/macOS/ChromeOS/Linux - Rugged TPE Construction (1P3FFCB-USB-SERIAL) - USB / serial cable - USB to DB-9 - 1 m
USB / serial cable
EMI/RFI protection, electrostatic discharge (ESD) protection, FTDI controller, LED status indicator, TPE connector housing, bus powered
Length
1 m
Connector
4 pin USB Type A - male
Connector (Second End)
9 pin D-Sub (DB-9) - male
USB / USB 2.0
USB / serial cable
Shielding Material
Copper
Plated Connector
Gold
Length
1 m
55 g
Connector
USB / USB 2.0, RS-232
Shipping Width
22 cm
Shipping Depth
0.1 cm
Shipping Height
2.2 cm
Shipping Weight
60 g
HKKL StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.05
HKKL StarTech.com 2m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £3.00
HKKL StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £5.03
HKKL StarTech.com 0.5m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.13
HKKL StarTech.com 1m Black DB9 RS232 Serial Null Modem Cable F/M In Stock £3.96
HKKL StarTech.com 10ft/3m USB to RS232 Serial Adapter In Stock £38.21
HKKL StarTech.com 6.6ft/2m USB to Serial Adapter In Stock £27.71
Length: 1m
