Hybrid USB Cable USB C Cable (10Gbps) with USB A Adapter (5Gbps) 2-Year Warranty. This hybrid 1-meter USB-C to C, USB 3.2 Gen 2 (10Gbps) cable with attached USB-A to C, USB 3.2 Gen 1 (5Gbps) adapter lets you connect a USB Type-C device, such as a docking station, hard drive, tablet or mobile device, to the USB-C or USB-A port on your host computer. The cable is also compatible with Thunderbolt 3 ports.
Note: When used with a USB-A host this cable will only work with docks that support DisplayLink.
Charge your USB Type-C devices faster
When used with a PD 3.0 enabled USB-C power source, the 1-meter USB-C to C cable supports up to 100W (5Amps) of power to charge a USB-C or Thunderbolt 3 laptop, tablet or smart phone.
Attached USB-C to USB-A adapter when paired with the USB-C to C cable also supports up to 15W (5V, 3Amps) of power to charge your devices from a USB-A wall charger, car charger or power bank - perfect for people on the move, for providing simple, tidy connections.
Connect your USB 3.1 peripherals
The USB 3.2 Gen 2, USB-C to C cable offers 10Gbps data rate, enabling you to sync your USB Type-C devices in no time at all. You'll also be able to connect your USB 3 (3.0, 3.1 or 3.2) peripheral devices, such as hard drive enclosures and docks, to your USB-C or TB3 laptop.
USB 3.2 Gen 1, USB-C to A adapter, when used with the USB-C to C cable, offers 5Gbps data rate. You can spend less time transferring and backing up your data from your USB-C devices to your USB-A host and focus more on your projects and presentations.
Hybrid Docking Station cable
Use this cable with your Hybrid USB-C Docking Station or USB-C Hub to connect your laptop, tablet, smart phone or portable drives. This cable also comes as an accessory for StarTech.com's Hybrid Dual Monitor (4K 60Hz) Docking Stations such as DK30C2DPEP and DK30C2DPPD.
The USBCCADP is backed by StarTech.com's 2-year warranty for guaranteed reliability.
                Charge your USB Type-C devices fasterWhen used with a PD 3.0 enabled USB-C power source, the 1-meter USB-C to C cable supports up to 100W (5Amps) of power to charge a USB-C or Thunderbolt 3 laptop, tablet or smart phone. Attached USB-C to USB-A adapter when paired with the USB-C to C cable also supports up to 15W (5V, 3Amps) of power to charge your devices from a USB-A wall charger, car charger or power bank - perfect for people on the move, for providing simple, tidy connections.
                Connect your USB 3.1 peripheralsThe USB 3.2 Gen 2, USB-C to C cable offers 10Gbps data rate, enabling you to sync your USB Type-C devices in no time at all. You'll also be able to connect your USB 3 (3.0, 3.1 or 3.2) peripheral devices, such as hard drive enclosures and docks, to your USB-C or TB3 laptop. USB 3.2 Gen 1, USB-C to A adapter, when used with the USB-C to C cable, offers 5Gbps data rate. You can spend less time transferring and backing up your data from your USB-C devices to your USB-A host and focus more on your projects and presentations.
                Hybrid Docking Station cableUse this cable with your Hybrid USB-C Docking Station or USB-C Hub to connect your laptop, tablet, smart phone or portable drives. This cable also comes as an accessory for StarTech.com's Hybrid Dual Monitor (4K 60Hz) Docking Stations such as DK30C2DPEP and DK30C2DPPD.
- StarTech.com 3ft (1m) USB C Cable w/ USB-A Adapter Dongle, Hybrid 2-in-1 USB C Cable w/ USB-A | USB-C to USB-C (10Gbps/100W PD), USB-A to USB-C (5Gbps), USB-A Host to USB-C DisplayLink Dock - Ideal for Hybrid Dock (USBCCADP) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 1 m
- USB-C cable
- USB Power Delivery (100W), 10 Gbps data rate, 5 Gbps data rate
- Length
- 1 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 2-year warranty
- Designed For
- P/N: DKM30CHDPD, DKM30CHDPDUE
- USB-C cable
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- PVC
- Length
- 1 m
- Connector
- Included Accessories
- USB-C to USB-A dongle
- RoHS
- Shipping Width
- 20 cm
- Shipping Depth
- 21.3 cm
- Shipping Height
- 5.1 cm
- Shipping Weight
- 64 g
- 2-year warranty
- Designed For
