Add RS-232 DCE serial communications support to a desktop or laptop computer and resolve DCE/DTE conflicts directly without the need for additional cross-wired serial cables or adapters.
Serial Port Expansion
The 3.3ft (1m) Null Modem USB Serial Adapter adds an RS-232 serial DB/DE-9 (female) connector to a desktop or laptop via a USB Type-A port. Secure the adapter to a serial device, using pre-installed and removable slotted D-Sub thumbscrews or install the included DB-9 Nuts for compatibility with other serial peripheral devices or cables. -
LED Indicators
Data transmission and reception LED indicators on the adapter provide real-time monitoring of port activity. The USB LED indicates when the adapter has successfully enumerated on the desktop or laptop. All the LEDs aid with diagnostics and troubleshooting. -
Seamless Connectivity
The adapter is compatible with Windows, macOS, ChromeOS, and Linux. Drivers automatically install to Windows 7 and newer versions, macOS 10.15 and above, and Linux. The USB to RS-232 adapter features COM retention, which automatically reassigns the COM port value if the cable is disconnected and reconnected, or if the system is rebooted. -
Built To Last
The rugged TPE construction and Level-4 ESD protection (15kV air and 8kV contact) enhance the reliability and longevity of the USB to Serial Adapter. Copper shielding minimizes Electromagnetic and Radio Frequency Interference (EMI and RFI). Gold-plated connectors enhance signal conductivity.
- StarTech.com 3ft (1m) USB to Null Modem Serial Adapter Cable, Interchangeable DB9 Screws/Nuts, COM Retention, USB-A to RS232, FTDI, Level-4 ESD Protection, Windows/macOS/ChromeOS/Linux - Rugged TPE Construction (1P3FFCNB-USB-SERIAL) - USB / serial cable - USB to DB-9 - 1 m
- EMI/RFI protection, electrostatic discharge (ESD) protection, FTDI controller, LED status indicator, TPE connector housing, bus powered
- Length
- 1 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 9 pin D-Sub (DB-9) - male
- USB / USB 2.0
- Black
- 2-year warranty
- Shielding Material
- Copper
- Plated Connector
- Gold
- Length
- 1 m
- Black
- 55 g
- Connector
- USB / USB 2.0, RS-232
- Shipping Width
- 2.2 cm
- Shipping Depth
- 0.01 cm
- Shipping Height
- 2 cm
- Shipping Weight
- 60 g
- 2-year warranty
StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.17 |
StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.26 |
StarTech.com 2m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £4.76 |
StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £5.33 |
StarTech.com 0.5m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £4.46 |
StarTech.com 10ft/3m USB to Null Modem Serial Cable | In Stock | £47.21 |
