Add RS-232 DCE serial communications support to a desktop or laptop computer and resolve DCE/DTE conflicts directly without the need for additional cross-wired serial cables or adapters.
                Serial Port ExpansionThe 3.3ft (1m) Null Modem USB Serial Adapter adds an RS-232 serial DB/DE-9 (female) connector to a desktop or laptop via a USB Type-A port. Secure the adapter to a serial device, using pre-installed and removable slotted D-Sub thumbscrews or install the included DB-9 Nuts for compatibility with other serial peripheral devices or cables.
                LED IndicatorsData transmission and reception LED indicators on the adapter provide real-time monitoring of port activity. The USB LED indicates when the adapter has successfully enumerated on the desktop or laptop. All the LEDs aid with diagnostics and troubleshooting.
                Seamless ConnectivityThe adapter is compatible with Windows, macOS, ChromeOS, and Linux. Drivers automatically install to Windows 7 and newer versions, macOS 10.15 and above, and Linux. The USB to RS-232 adapter features COM retention, which automatically reassigns the COM port value if the cable is disconnected and reconnected, or if the system is rebooted.
                Built To LastThe rugged TPE construction and Level-4 ESD protection (15kV air and 8kV contact) enhance the reliability and longevity of the USB to Serial Adapter. Copper shielding minimizes Electromagnetic and Radio Frequency Interference (EMI and RFI). Gold-plated connectors enhance signal conductivity.
- StarTech.com 3ft (1m) USB to Null Modem Serial Adapter Cable, Interchangeable DB9 Screws/Nuts, COM Retention, USB-A to RS232, FTDI, Level-4 ESD Protection, Windows/macOS/ChromeOS/Linux - Rugged TPE Construction (1P3FFCNB-USB-SERIAL) - USB / serial cable - USB to DB-9 - 1 m
- EMI/RFI protection, electrostatic discharge (ESD) protection, FTDI controller, LED status indicator, TPE connector housing, bus powered
- Length
- 1 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 9 pin D-Sub (DB-9) - male
- USB / USB 2.0
- Black
- 2-year warranty
- Shielding Material
- Copper
- Plated Connector
- Gold
- Length
- 1 m
- Black
- 55 g
- Connector
- USB / USB 2.0, RS-232
- Shipping Width
- 2.2 cm
- Shipping Depth
- 0.01 cm
- Shipping Height
- 2 cm
- Shipping Weight
- 60 g
- 2-year warranty
|  | StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.04 |
|  | StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.29 |
|  | StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £5.03 |
|  | StarTech.com 0.5m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £4.12 |
|  | StarTech.com 10ft/3m USB to Null Modem Serial Cable | In Stock | £38.21 |
|  | StarTech.com USB Serial DCE Adapter Cable 2m | In Stock | £25.79 |
