USB Type-C Adapter Cable HDR10 Ultra HD Thunderbolt 3 Host Compatible. This USB-C to HDMI cable lets you connect your USB Type-C (supporting DP Alt Mode) or Thunderbolt 3 device to an HDMI display. The display cable supports High Dynamic Range (HDR10) and provides sharper images with enhanced video.
With brighter colors and greater contrast, the video adapter cable is ideal for:
• Creating eye-catching visuals for photography, videography, cinematography
• Displaying crisp digital signage walls
• Delivering enriched presentations
True 4K at 60Hz and HDR
The USB-C video converter cable is fully compatible with your HDMI 2.0b equipment, supporting resolutions up to 4K 60Hz (3840x2160) and bandwidths up to 18Gbps. The cable offers 4:4:4 chroma subsampling, so every pixel gets its own unique color. It's also backward compatible with earlier versions of HDMI.
With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging.
Clutter-Free Installation
At 1m (3.3ft) in length, this cable cord delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation.
Hassle-Free Setup
To ensure easy operation and installation, this USB-C to HDMI cable supports a seamless plug & play setup with any OS, including macOS, Windows, Linux, Chrome and Android.
CDP2HDMM1MH is backed by a 3-year StarTech.com warranty and free lifetime technical support.
Notes:
To achieve HDR, your USB-C port must support DisplayPort 1.4 and your display must support HDMI 2.0b
NVIDIA graphics adapters may not support 4:4:4 chroma subsampling and 5.1/7.1 audio output, when used with this adapter cable.
                High performanceThe adapter cable supports Ultra HD (UHD) resolutions with HDR, 7.1ch audio, HDCP, DisplayPort, Alt Mode HBR3. Backward compatible with 1080p.
                Integrated display cable with HDRColor spacing supporting RGB and YCbCr for high-contrast and lifelike color with HDMI displays. The chip built into the HDMI connector minimizes signal loss and failure points, provides tidy installation.
                Easy to useThe USB Type-C to HDMI adapter cable has been tested to ensure compatibility with USB Type-C DP Alt Mode or TB3 devices. Driverless plug-and-play setup.
                True 4K and HDRThe USB Type-C video converter cable is fully compatible with your HDMI 2.0b equipment, supporting resolutions up to 4K and high bandwidths. The cable offers 4:4:4 Chroma subsampling, so every pixel gets its own unique color. It's also backward compatible with earlier versions of HDMI. With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity.
                Clutter-free installationThis cable cord delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation.
                Hassle-free setupTo ensure easy operation and installation, this USB Type-C to HDMI cable supports a seamless plug-and-play setup with any OS.
- StarTech.com 3ft (1m) USB C to HDMI Cable 4K 60Hz with HDR10, Ultra HD USB Type-C to 4K HDMI 2.0b Video Adapter Cable, USB-C to HDMI HDR Monitor/Display Converter, DP 1.4 Alt Mode HBR3 - Thunderbolt 3 Compatible (CDP2HDMM1MH) - adapter cable - HDMI / USB - 1 m
- Cable
- Adapter cable - HDMI / USB
- Max Output Resolution
- 3840 x 2160 - 60 Hz
- Length
- 1 m
- Black
- Connector
- 24 pin USB-C - male (input)
- Connector (Second End)
- HDMI - male (output)
- Thunderbolt 3 / DisplayPort 1.4
- 4K support, active adapter
- 3-year warranty
- Cable Type
- Adapter cable 4K support, active
- Interface Supported
- HDMI / USB
- Length
- 1 m
- HBR3 audio support, HDR 10 support, 8/10 bit deep colour, DisplayPort Alternate Mode support, 7.1 PCM audio channel support, Realtek RTD2172U chipset
- Black
Adapters & Converters
- 3840 x 2160
- Refresh Rate
- 60 Hz
- OS Required
- Apple MacOS, Linux, Microsoft Windows, Android, Google Chrome OS
- Connector
- 19 pin HDMI Type A - male (output)
- Plug and Play, FCC, RoHS, WEEE, RCM, HDCP 2.2, HDCP 1.4
- 2.2 cm
- 1.2 cm
- 41 g
- Shipping Width
- 21.8 cm
- Shipping Depth
- 20 cm
- Shipping Height
- 1 cm
- Shipping Weight
- 50 g
- Limited warranty - 3 years
|  | StarTech.com USB-C to HDMI Adapter Cable | In Stock | £25.07 |
|  | StarTech.com USB-C to HDMI Adapter Cable | In Stock | £27.22 |
|  | StarTech.com 10ft/3m USB-C to HDMI Adapter Cable | In Stock | £40.86 |
