StarTech.com 3ft (1m) Thunderbolt Cable
Quicklinx: HFP7WS00 Mfr#: TBLT4MM1M
Length: 1m
14 In Stock
£40.49 ex VAT
£48.58 inc VAT
This Thunderbolt 4 (40 Gbps) cable enables Thunderbolt 4 signals over USB Type-C connectors. Deliver video, data, and up to 100W of Power Delivery to Thunderbolt, USB, and DisplayPort devices.
  • 40 Gbps for Thunderbolt 4 / 3 Devices
    This cable supports data transfer of 40 Gbps when connected to a Thunderbolt 4, Thunderbolt 3, or USB4-compatible source and device. It is capable of transferring photo and video files four times faster than standard USB 3.2 gen 2 (10Gbps) cables.
  • USB-C Compatible
    The Thunderbolt 4 cable is compatible with all USB Type-C devices and can be used to charge and sync mobile devices. In addition, this cable can be used to connect and power USB-C laptops, such as MacBook and Chromebook ; and USB-C peripherals such as portable hard drives and docking stations.
  • Full-8K Video
    The cable supports full-8K 60Hz video and DisplayPort 1.4a, and is compatible with DisplayPort displays. Use it to connect a docking station to laptop, or a laptop to a display
  • USB Power Delivery
    This Thunderbolt 4 cable delivers up to 100W of Power Delivery to charge a laptop or power a display, and 15W for bus-powered devices such as hard drive enclosures.
  • Thunderbolt Networking
    The cable can be used to daisy chain up to 6 Thunderbolt 4 enabled devices, such as laptops for peer-to-peer 10GbE networking. In addition, connect two Thunderbolt 4 laptops to transfer/migrate data.
StarTech 3ft (1m) Thunderbolt 4 Cable, 40Gbps, 100W Power Delivery, 4K/8K Video, Intel-Certified Thunderbolt Cable - Compatible w/ USB 4/Thunderbolt 4/ USB 3.2/ USB Type-C/DisplayPort/Thunderbolt 3 (TBLT4MM1M) - Thunderbolt cable - Thunderbolt 4 to Thunderbolt 4 - 1 m
Thunderbolt cable
4K support, 8K support, passive adapter, USB Power Delivery (100W), 40 Gbps data rate, Intel certified
Cable Length
1 m
Connector
Thunderbolt 4 - male
Connector (Second End)
USB4/Thunderbolt 3/USB 3.2/USB Type-C/DisplayPort
Thunderbolt cable
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
30/34
Plated Connector
Nickel
Cable Length
1 m
Outside Diameter
4.6 mm
Connector
USB4/Thunderbolt 3/USB 3.2/USB Type-C/DisplayPort, FCC, RoHS, WEEE, halogen-free
Shipping Width
12.8 cm
Shipping Depth
22 cm
Shipping Height
2 cm
HFP7 StarTech.com 3ft USB4 Cable, USB-C 40 Gbps In Stock £20.69
HFP7 StarTech.com 6ft (2m) Thunderbolt Cable In Stock £82.27
HFP7 StarTech.com 1m USB4 Cable, USB-C 40 Gbps In Stock £20.51
HFP7 StarTech.com 1.6ft USB4 Cable, USB-C 40Gbps In Stock £19.39
HFP7 StarTech.com 3ft (1m) Thunderbolt 5 Cable In Stock £32.51
HFP7 StarTech.com 1.5ft/50cm Thunderbolt 5 Cable In Stock £29.30
HFP7 StarTech.com 2.6ft/80cm Thunderbolt 5 Cable In Stock £30.97
HFP7 StarTech.com 3ft/1m Thunderbolt 5 Cable In Stock £32.24
HFP7 StarTech.com 1.5ft/50cm Thunderbolt 5 Cable In Stock £30.73
HFP7 StarTech.com 2.6ft/80cm Thunderbolt 5 Cable In Stock £32.09
Length: 1m
