Brand
StarTech.com 36in SATA Serial ATA Cable
Quicklinx: 4KXJWS00 Mfr#: SATA36
Length: 0.9m
Type: ATA
£3.41 ex VAT
£4.09 inc VAT
Connect and position SATA drives easily - designed for larger cases. The SATA36 Serial ATA Cable features two 7-pin data receptacles and supports full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives.
Featuring a low profile, yet durable construction, the flexible design improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
StarTech.com 36in SATA Serial ATA Cable - SATA cable - Serial ATA 150 - SATA (F) to SATA (F) - 3 ft - red - SATA36 - SATA cable - 0.9 m
SATA cable
Interface Speed
Serial ATA 150
Length
0.9 m
Connector
7 pin Serial ATA - female
Connector (Second End)
Red
P/N: 10P6G-PCIE-SATA-CARD, 25SAT35HDD, 2P6G-PCIE-SATA-CARD, 4P6G-PCIE-SATA-CARD, 6P6G-PCIE-SATA-CARD, BRACKET25SAT, CFAST2SAT25, IDE2SAT25, PATA2SATA3, PEXSAT32, PEXSATA22I, S25SLOTR, SAT2MSAT25, SATABAY5BK, SATBP125VP, SATSASBAY3BK, USB2SATAIDE, USB3SSATAIDE
Storage Cable Type
SATA cable
Interface Speed
Serial ATA 150
Length
0.9 m
Red
Connector
4KXJ StarTech.com 36in SATA Serial ATA Cable In Stock £3.41
4KXJ StarTech.com 36in SATA to Right Angle SATA Serial ATA Cable In Stock £3.06
Length: 0.9m
Type: ATA
Stock Status: In stock
