StarTech.com 35 ft Cat 6 Gray Molded RJ45 UTP Gigabit Cat6 Patch Cable
Quicklinx: 7RPSWS00 Mfr#: C6PATCH35GR
Length: 10.7m
Colour: Grey
13 in stock
£10.20 ex VAT
£12.24 inc VAT
Make Power-over-Ethernet-capable Gigabit network connections. The C6PATCH35GR Cat 6 Patch Cable (35 ft) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable gray PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat 6 patch cable features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Gigabit Patch Cable delivers reliable performance.
  • 100% copper - a better value
    StarTech.com Cat6 cables are manufactured using high-quality copper conductors. While many cable manufacturers offer a "cheaper" cable, based on a copper-coated aluminum core, StarTech.com makes no compromises on quality to ensure you receive top value and performance for your network cable investment.
  • 24 AWG wire
    This Cat6 cable is constructed with 24 gauge copper wire, to support a broad range of Ethernet applications such as Power over Ethernet (PoE). Because StarTech.com uses a high quality copper wire, these cables easily sustain the power required for Power over Ethernet applications, whereas the inferior quality offered by copper-coated aluminum cables may be subject to insufficient power delivery, heat buildup, equipment damage and potentially, fire.
  • 50-micron gold connectors
    This molded patch cable offers high quality connectors comprised of 50-micron gold, to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
StarTech.com 35ft CAT6 Ethernet Cable - Gray Molded Gigabit CAT 6 Wire - 100W PoE RJ45 UTP 650MHz - Category 6 Network Patch Cord UL/TIA (C6PATCH35GR) - patch cable - 10.7 m - grey
Patch cable - CAT 6
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded
Length
10.7 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Molded
Length
10.7 m
Grey
Connector
RJ-45 - male
RJ-45 - male
CSA, ETL - up to 650 MHz
Length: 10.7m
Colour: Grey
Price Range Ex VAT: 0 - 50
