Ships Flat-Packed
The cabinet comes in a flat packed box to reduce shipping volume, which significantly reduces your costs in shipping. Plus, because the rack is packaged efficiently, you can easily store the cabinet, for deployment at a later date.
- StarTech.com 32U 19" Server Rack Cabinet, Adjustable Depth 6-32 inch, Lockable 4-Post Network/Data/AV Equipment Rack Enclosure w/ Glass Door & Casters, Flat Pack, 1763lb/800kg Capacity - Free Standing Server Rack (RK3236BKF) - rack - 32U
- Product Type
- Rack
- Rack Type
- Cabinet - 4-post
- Placing / Mounting
- Floor-standing
- Package Content
- Phillips screwdriver, 2 casters, top panel, front door, rear door, 2 side panel keys, 2 door keys, 4 x levelling feet, 40 M6 cage nuts, 2 casters with locking device, 2 side panel and frame, 4 upper and lower beams, 2 bottom panel with cable management slot, bottom panel (solid), 8 plastic corner caps, 8 M8-20 hex screws, 8 M8 spring washers, 8 M4-10 flat head screws, 4 M6-12 hex screws, 6 M5-12 screws, M6 hex key, M8 hex key, 16 M6-10 Phillips bolts, 2 door hinge pins, 40 M6-12 Phillips screws, 40 M6 plastic cup washers
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 32U
- Product Material
- Glass, steel
- 60 cm x 1 m x 162 cm
- Key lock, integrated cable management, flat pack, adjustable mounting rails
- Limited lifetime warranty
- Product Type
- Rack
- Rack Type
- Cabinet
- Rack Post Qty
- 4-post
- Floor-standing
- Product Material
- Glass, steel
- Package Content
- Rack Size
- 19"
- 32U
- 60 cm
- 1 m
- 162 cm
- Black
- Weight Limit
- 800 kg
- EIA-310-C, RoHS, REACH, ECA-310-E
- Limited warranty: - lifetime
StarTech.com 16 Port 1U Rackmount USB PS/2 KVM Switch with OSD | In Stock | £488.55 |
StarTech.com 8 Port 1U Rackmount USB PS/2 KVM Switch with OSD | In Stock | £270.79 |
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg | In Stock | £96.93 |
StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails | In Stock | £84.93 |
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £12.34 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £30.51 |
StarTech.com Black Standard Universal Server Rack Cabinet Shelf | In Stock | £31.10 |
StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £477.22 |
StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) | In Stock | £335.92 |
StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet | In Stock | £14.45 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £28.56 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £54.09 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £57.23 |
StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg | In Stock | £25.89 |
StarTech.com 22in Black Deep Sliding Server Rack Cabinet Shelf | In Stock | £92.13 |
StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables | In Stock | £542.00 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £284.45 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables | In Stock | £317.76 |
StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch | In Stock | £635.38 |
StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg | In Stock | £86.73 |
StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets | In Stock | £101.34 |
StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails | In Stock | £63.29 |
StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails | In Stock | £77.90 |
StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel | In Stock | £33.04 |
StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg | In Stock | £73.91 |
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg | In Stock | £82.73 |
StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg | In Stock | £55.31 |
StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg | In Stock | £44.71 |
StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg | In Stock | £37.48 |
StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg | In Stock | £52.08 |
StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) | In Stock | £3.06 |
StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) | In Stock | £4.40 |
StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) | In Stock | £6.45 |
StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel | In Stock | £39.94 |
StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 50lbs / 22.7kg | In Stock | £162.10 |
StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel | In Stock | £46.00 |
StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £17.96 |
StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £23.35 |
StarTech.com 1U Server Rack Panel | In Stock | £11.99 |
StarTech.com 100 Pkg M6 Screws & Cage Nuts | In Stock | £57.09 |
StarTech.com 50 Pkg M6 Screws & Cage Nuts | In Stock | £30.44 |
StarTech.com 100 Pkg M5 Cage Nuts | In Stock | £26.80 |
StarTech.com 50 Pkg M6 Cage Nuts | In Stock | £20.46 |
StarTech.com 100 Pkg M5 Cage Nuts | In Stock | £28.99 |
StarTech.com 50 Pkg M5 Cage Nuts | In Stock | £15.59 |
StarTech.com 100 Pkg M5 Screws & Cage Nuts | In Stock | £54.01 |
StarTech.com 50 Pkg M5 Screws & Cage Nuts | In Stock | £29.06 |
StarTech.com 50 Pkg M5 Mounting Screws | In Stock | £16.04 |
StarTech.com 100 Pkg M5 Mounting Screws | In Stock | £29.99 |
StarTech.com 50 Pkg M6 Mounting Screws | In Stock | £16.75 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £27.29 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £28.49 |
StarTech.com 19in Cable Management Panel | In Stock | £23.30 |
StarTech.com M6 Mounting Screws 50Pack | In Stock | £16.78 |
