StarTech.com 32U 19 inch Server Rack Cabinet
Quicklinx: GFJ1WS00 Mfr#: RK3236BKF
Hurry, only 3 left in stock!
£1,098.87 ex VAT
£1,318.64 inc VAT
Knock Down Server Rack - EIA-310 - 4 Post - Weight Cap. 1763 lb. - Lockable.
  • Ships Flat-Packed
    The cabinet comes in a flat packed box to reduce shipping volume, which significantly reduces your costs in shipping. Plus, because the rack is packaged efficiently, you can easily store the cabinet, for deployment at a later date.
StarTech.com 32U 19" Server Rack Cabinet, Adjustable Depth 6-32 inch, Lockable 4-Post Network/Data/AV Equipment Rack Enclosure w/ Glass Door & Casters, Flat Pack, 1763lb/800kg Capacity - Free Standing Server Rack (RK3236BKF) - rack - 32U
Rack
Rack Type
Cabinet - 4-post
Placing / Mounting
Floor-standing
Package Content
Phillips screwdriver, 2 casters, top panel, front door, rear door, 2 side panel keys, 2 door keys, 4 x levelling feet, 40 M6 cage nuts, 2 casters with locking device, 2 side panel and frame, 4 upper and lower beams, 2 bottom panel with cable management slot, bottom panel (solid), 8 plastic corner caps, 8 M8-20 hex screws, 8 M8 spring washers, 8 M4-10 flat head screws, 4 M6-12 hex screws, 6 M5-12 screws, M6 hex key, M8 hex key, 16 M6-10 Phillips bolts, 2 door hinge pins, 40 M6-12 Phillips screws, 40 M6 plastic cup washers
Rack Size
19"
Height (Rack Units)
32U
Product Material
Glass, steel
60 cm x 1 m x 162 cm
Key lock, integrated cable management, flat pack, adjustable mounting rails
Rack
Rack Type
Cabinet
Rack Post Qty
4-post
Placing / Mounting
Floor-standing
Product Material
Glass, steel
Package Content
Rack Size
19"
Height (Rack Units)
32U
60 cm
1 m
162 cm
Weight Limit
800 kg
EIA-310-C, RoHS, REACH, ECA-310-E
Limited warranty: - lifetime
GFJ1 StarTech.com 8 Port 1U Rackmount USB PS/2 KVM Switch with OSD In Stock £265.47
GFJ1 StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £94.63
GFJ1 StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet In Stock £45.84
GFJ1 StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £79.45
GFJ1 StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.20
GFJ1 StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
GFJ1 StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £30.71
GFJ1 StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £464.07
GFJ1 StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) In Stock £351.41
GFJ1 StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.24
GFJ1 StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
GFJ1 StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.53
GFJ1 StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £25.30
GFJ1 StarTech.com 22in Black Deep Sliding Server Rack Cabinet Shelf In Stock £91.53
GFJ1 StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £527.07
GFJ1 StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £280.59
GFJ1 StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £317.20
GFJ1 StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch In Stock £543.36
GFJ1 StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg In Stock £86.88
GFJ1 StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets In Stock £100.66
GFJ1 StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £62.88
GFJ1 StarTech.com 2U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £72.65
GFJ1 StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £77.01
GFJ1 StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £15.50
GFJ1 StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £77.01
GFJ1 StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £81.75
GFJ1 StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £56.70
GFJ1 StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £44.28
GFJ1 StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £37.00
GFJ1 StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £51.38
GFJ1 StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) In Stock £3.06
GFJ1 StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.24
GFJ1 StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £6.36
GFJ1 StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £38.59
GFJ1 StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 50lbs / 22.7kg In Stock £158.72
GFJ1 StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 125lbs / 56.7kg In Stock £162.14
GFJ1 StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £47.16
GFJ1 StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £17.75
GFJ1 StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £23.11
GFJ1 StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £56.58
GFJ1 StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.63
GFJ1 StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.19
GFJ1 StarTech.com 100 Pkg M5 Cage Nuts In Stock £9.55
GFJ1 StarTech.com 50 Pkg M5 Cage Nuts In Stock £5.39
GFJ1 StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £53.55
GFJ1 StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £28.25
GFJ1 StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.69
GFJ1 StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.56
GFJ1 StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.11
GFJ1 Startech.com 100 Pkg M6 Mounting Screws In Stock £26.84
GFJ1 StarTech.com 19in Cable Management Panel In Stock £24.18
GFJ1 StarTech.com M6 Mounting Screws 50Pack In Stock £16.56
Price Range Ex VAT: £1000 - £1500
