StarTech.com 31.5" Monitor Privacy Screen
Quicklinx: HSV9WS00 Mfr#: 31569-PRIVACY-SCREEN
12 In Stock
£114.96 ex VAT
£137.95 inc VAT
The StarTech.com 31.5-inch Computer Monitor Privacy Screen/Filter is designed to protect sensitive information from prying eyes while enhancing your viewing experience. With its 2-way privacy protection, this filter limits the viewing angle to +/- 30°, ensuring that your data stays private, even in busy environments. The screen is not only removable but also features a dual finish (glossy/matte) that allows you to choose between a clear or anti-glare view, reducing blue light exposure and minimizing glare for a more comfortable viewing experience. Additionally, its scratch-resistant and fingerprint-resistant surface maintains a clear, unobstructed view of your display. Installation is simple, thanks to the included adhesive strips, mounting tabs kit, and wiping cloth, making it an ideal choice for anyone looking to secure their information without sacrificing screen clarity or quality. Whether you're working in an open office, traveling, or any place where privacy is a concern, the StarTech.com privacy screen/filter offers an effective solution to keep your information confidential.
  • Enhanced privacy
    The 31.5-inch 16:9 Computer Monitor Privacy Screen/Filter from StarTech.com offers 2-way privacy protection, ensuring your data remains confidential with +/- 30° visible angle, making it perfect for high traffic areas or open office environments.
  • Versatile viewing
    Featuring a unique glossy/matte surface finish, this privacy screen allows you to choose your preferred viewing experience while reducing glare and harmful blue light, making it easier on the eyes during extended use.
  • Durable design
    Designed with scratch-resistant and fingerprint-resistant coatings, this privacy filter stands up to daily wear and tear while keeping your screen clear and readable, ensuring long-lasting clarity and protection.
  • Easy installation
    With Plug-and-Play/adhesive installation options, mounting tabs kit, and included wiping cloth, setting up your privacy screen is hassle-free, allowing for a secure fit on your 31.5" monitor and easy removal without residue.
StarTech.com 31.5-inch 16:9 Computer Monitor Privacy Screen/Filter - display privacy filter - 31.5"
Display privacy filter - 2-way
Installation Type
Removable - plug-in/adhesive
Package Content
2 adhesive strips, wiping cloth, mounting tabs kit
Display Screen Size Compatibility
31.5"
Product Material
Plastic
69.6 cm x 39.3 cm x 0.04 cm
100 g
Package Content
31.5"
Product Material
Plastic
69.6 cm - 39.3 cm - 0.04 cm
100 g
42.5 cm x 73.5 cm x 0.64 cm / 600 g
Display Filter
Privacy Protection
2-way
Installation Type
Aspect Ratio
16:9
Surface Finish
Glossy/matte
Scratch Resistant
Mounting Kit
Included
Anti-glare, fingerprint-resistant coating, horizontal orientation, +/- 30° visible angle, blue light reduction, 60% light transmittance
HSV9 StarTech.com Privacy Screen Dell P3424WE In Stock £122.53
