StarTech.com 30U Vertical Cable Manager
Quicklinx: 8370WS00 Mfr#: CABLMANAGER3
Organize and manage network, server and KVM cabling in your server rack. The CABLMANAGER3 30U Vertical Server Rack Cable Manager with Hinged Cover can be mounted to a 2 or 4 post rack to provide efficient cable organization.
Featuring a high-capacity cable channel and a hinged door that provides easy access for the addition or removal of cables, this server rack cable management panel offers rear and side pass-through holes for easy cable routing to all of your rack mounted devices.
The vertical cable organizer is a durable solution for server room and structured wiring closet applications, perfect for routing patch panel and other rackmount equipment wiring in an orderly fashion.
StarTech.com 30U Vertical Server Rack Cable Manager with Hinged Cover - cable management rack - 30U
Cable management rack
Package Content
Washer, 8 M8 screws, 8 nuts
Height (Rack Units)
30U
Product Material
Steel
13 cm x 16 cm x 135 cm
7.3 kg
P/N: RK4242BK
Product Material
Steel
Package Content
Height (Rack Units)
30U
13 cm
16 cm
135 cm
7.3 kg
Limited warranty: - lifetime
P/N: RK4242BK
