StarTech.com 30m SC to SC OS2 Fiber Cable
Quicklinx: HM0XWS00 Mfr#: SPSMSCSC-OS2-30M
Length: 30m
Colour: Yellow
£49.56 ex VAT
£59.47 inc VAT
SIMPLEX OS2 CABLE: Single Mode Simplex OS2 Fiber Cable is immune to EMI and optimized for 40G/100Gbps networks; Supports bi-directional (BiDi) transmission over a single fiber; Ideal for space-constrained installations requiring minimal fiber count.
QUALITY CONSTRUCTION: SC/SC-UPC ends for improved return loss over PC polish; Bend Insensitive fiber core housed in Aramid-reinforced jacket for a loaded bend radius of 10mm.
SAFETY AND RELIABILITY: Individually tested for guaranteed performance; Test report included; LSZH jacket emits low toxic fumes if combusted; Safe for enclosed/poorly ventilated spaces; Attenuation value under 0.35dB/km outperforms industry standards.
COMPATIBILITY: Simplex Single Mode Fiber Patch Cord supports 40G/100G networks; Backward compatible with OS1; High micro-bend resistance facilitates tight bends in complex installations; Ideal for point-to-point setups or single-fiber NICs and SFPs.
SPECS: 30 meter (98.4 foot); OS2 Single Mode; SC/SC (UPC) Simplex; 100Gbps; 9/125µm; 1260-1625nm Laser Optimized; Insertion Loss: =0.3dB; Return Loss: =55dB; Cable OD: 2mm; Bend Radius: 10mm (0.39in) loaded/unloaded.
  • High performance
    Experience seamless data transmission with the StarTech.com 30m SC to SC Single Mode Simplex Fiber Optic Cable, designed to support up to 100 Gbps. Its low insertion loss and high return loss ensure efficient signal transfer, making it suitable for high-demand applications.
  • Durable design
    Built with a Low Smoke Zero Halogen (LSZH) jacket and a ceramic ferrule, this cable is not only bend insensitive with a bending radius of 10 mm but also prioritizes your safety by emitting less toxic and corrosive gas when exposed to high heat.
  • Advanced technology
    Featuring Coarse Wavelength Division Multiplexing (CWDM) support and a wavelength range of 1260-1625 nm, this cable is engineered for bidirectional communication and is equipped to handle the demands of modern networks.
StarTech.com 30m (98.4ft) SC to SC (UPC) OS2 Single Mode Simplex Fiber Optic Cable, 9/125µm, 40G/100G, Bend Insensitive, Low Insertion Loss, LSZH Fiber Patch Cord - patch cable - 30 m - yellow
Patch cable - OS1/OS2
Simplex fibre optic
Type of Fibre Optics
Singlemode
Halogen-free, passive adapter, bi-directional, ceramic ferrule, bend insensitive, low insertion loss, bending radius 10mm, up to 100 Gbps, 0.3 dB insertion loss, 55 dB return loss, wavelength of 1260-1625 nm, Coarse Wavelength Division Multiplexing (CWDM) support
Length
30 m
Diameter
2 mm
Core / Cladding Diameter
9 / 125 micron
Connector
SC/UPC single-mode - male
Connector (Second End)
Yellow
Network Cable Type
Simplex fibre optic
Singlemode
Jacket Material
9 / 125 micron
Length
30 m
Diameter
2 mm
Yellow
Connector
RoHS, WEEE, EMI
Shipping Width
20 cm
Shipping Depth
22 cm
Shipping Height
1.2 cm
Shipping Weight
112.5 g
-20 °C
60 °C
Length: 30m
Colour: Yellow
