StarTech.com 30m SC to SC OS2 Fiber Cable
Quicklinx: HM0WWS00 Mfr#: SPSMSCSC-OS2-100M
Length: 100m
Colour: Yellow
10 In Stock
£240.18 ex VAT
£288.21 inc VAT
High Quality and Cost-effective 9/125µm Single Mode Bend Insensitive Fiber Optic Cable
The 9/125µm OS2 single mode bend insensitive fiber optic cable has less attenuation when bent or twisted compared with traditional optical fiber cables and this will make the installation and maintenance of the fiber optic cables more efficient. It can also save more space for your high-density cabling in data centers, enterprise networks, telecom rooms, server farms, cloud storage networks, and interconnect pre-terminated cassettes in main distribution, horizontal distribution, and equipment distribution areas fiber patch cables are needed.
This 9/125 OS2 single mode fiber optic cable is ideal for connecting 1G/10G/25G/40G/100G/400G Ethernet connections. It can transport data for up to 10km at 1310nm, or up to 40km at 1550nm.
  • Bend insensitive design
    Engineered for resilience, this fiber optic cable boasts a bend-insensitive design, ensuring uninterrupted data transmission even in tight spaces with a bending radius of just 10 mm. Its aramid fiber reinforcement adds an extra layer of durability, making it a suitable choice for complex network setups.
  • High performance connectivity
    Featuring a low insertion loss of just 0.3 dB and a high return loss of 55 dB, this cable supports Coarse Wavelength Division Multiplexing (CWDM), allowing for multiple wavelength signals to be transmitted simultaneously over a single fiber. This capability, combined with support for up to 100 Gbps, makes it perfectly suited for high-bandwidth applications.
  • Eco-friendly and safe
    Constructed with a Low Smoke Zero Halogen (LSZH) jacket, this cable minimizes the emission of toxic fumes in the event of a fire, making it a safer choice for enclosed spaces. Its halogen-free nature also makes it an environmentally friendly option for your networking needs.
StarTech.com 100m (328ft) SC to SC (UPC) OS2 Single Mode Simplex Fiber Optic Cable, 9/125µm, 40G/100G, Bend Insensitive, Low Insertion Loss, LSZH Fiber Patch Cord - patch cable - 100 m - yellow
Patch cable - OS1/OS2
Simplex fibre optic
Type of Fibre Optics
Singlemode
Halogen-free, passive adapter, bi-directional, ceramic ferrule, bend insensitive, low insertion loss, bending radius 10mm, aramid fibre reinforced, up to 100 Gbps, 0.3 dB insertion loss, 55 dB return loss, wavelength of 1260-1625 nm, Coarse Wavelength Division Multiplexing (CWDM) support
Length
100 m
Diameter
2 mm
Core / Cladding Diameter
9 / 125 micron
Connector
SC/UPC single-mode - male
Connector (Second End)
Yellow
Network Cable Type
Simplex fibre optic
Singlemode
Jacket Material
9 / 125 micron
Length
100 m
Diameter
2 mm
Yellow
Connector
RoHS, WEEE, EMI
Shipping Width
28 cm
Shipping Depth
28 cm
Shipping Height
1.8 cm
Shipping Weight
356.1 g
-20 °C
60 °C
Length: 100m
Colour: Yellow
