High Quality and Cost-effective 9/125µm Single Mode Bend Insensitive Fiber Optic Cable
The 9/125µm OS2 single mode bend insensitive fiber optic cable has less attenuation when bent or twisted compared with traditional optical fiber cables and this will make the installation and maintenance of the fiber optic cables more efficient. It can also save more space for your high-density cabling in data centers, enterprise networks, telecom rooms, server farms, cloud storage networks, and interconnect pre-terminated cassettes in main distribution, horizontal distribution, and equipment distribution areas fiber patch cables are needed.
This 9/125 OS2 single mode fiber optic cable is ideal for connecting 1G/10G/25G/40G/100G/400G Ethernet connections. It can transport data for up to 10km at 1310nm, or up to 40km at 1550nm.
Bend insensitive design
Engineered for resilience, this fiber optic cable boasts a bend-insensitive design, ensuring uninterrupted data transmission even in tight spaces with a bending radius of just 10 mm. Its aramid fiber reinforcement adds an extra layer of durability, making it a suitable choice for complex network setups. -
High performance connectivity
Featuring a low insertion loss of just 0.3 dB and a high return loss of 55 dB, this cable supports Coarse Wavelength Division Multiplexing (CWDM), allowing for multiple wavelength signals to be transmitted simultaneously over a single fiber. This capability, combined with support for up to 100 Gbps, makes it perfectly suited for high-bandwidth applications. -
Eco-friendly and safe
Constructed with a Low Smoke Zero Halogen (LSZH) jacket, this cable minimizes the emission of toxic fumes in the event of a fire, making it a safer choice for enclosed spaces. Its halogen-free nature also makes it an environmentally friendly option for your networking needs.
- StarTech.com 100m (328ft) SC to SC (UPC) OS2 Single Mode Simplex Fiber Optic Cable, 9/125µm, 40G/100G, Bend Insensitive, Low Insertion Loss, LSZH Fiber Patch Cord - patch cable - 100 m - yellow
- Patch cable - OS1/OS2
- Technology
- Simplex fibre optic
- Type of Fibre Optics
- Singlemode
- Halogen-free, passive adapter, bi-directional, ceramic ferrule, bend insensitive, low insertion loss, bending radius 10mm, aramid fibre reinforced, up to 100 Gbps, 0.3 dB insertion loss, 55 dB return loss, wavelength of 1260-1625 nm, Coarse Wavelength Division Multiplexing (CWDM) support
- Length
- 100 m
- Diameter
- 2 mm
- Core / Cladding Diameter
- 9 / 125 micron
- Connector
- SC/UPC single-mode - male
- Connector (Second End)
- Yellow
- Limited lifetime warranty
- Network Cable Type
- Technology
- Singlemode
- Jacket Material
- Low Smoke Zero Halogen (LSZH)
- 9 / 125 micron
- Length
- 100 m
- Diameter
- 2 mm
- Yellow
- Connector
- RoHS, WEEE, EMI
- Shipping Width
- 28 cm
- Shipping Depth
- 28 cm
- Shipping Height
- 1.8 cm
- Shipping Weight
- 356.1 g
- -20 °C
- 60 °C
