StarTech.com 30m LC to SC OS2 Fiber Cable
Quicklinx: HMPWWS00 Mfr#: SPSMLCSC-OS2-15M
Length: 15m
Colour: Yellow
£25.51 ex VAT
£30.61 inc VAT
OS2 LC to SC Single Mode Simplex Fiber Optic Patch cable facilitates connectivity across 40G/100G networks. It supports Coarse Wavelength Division Multiplexing (CWDM) across an extended wavelength range of 1260-1625nm, improving channel isolation for optimal signal strength over long distances.
  • Compatibility
    Connect to single-fiber networking devices including simplex patch panels, SFP transceivers, and fiber NICs. This 9/125µm OS2 simplex single mode fiber patch cord is backward compatible with OS1 networks, ensuring a reliable connection in legacy fiber environments.
  • Engineered for Optimal Performance
    Precision-manufactured ceramic ferrules ensure accurate fiber alignment for an insertion loss below 0.3dB. Ultra Physical Contact (UPC)-polished LC to SC fiber ends greatly improve return loss characteristics over older PC polishing techniques. The Bend Insensitive fiber core is surrounded by a layer of low refractive index material. This material reduces the amount of light that can escape the fiber cable by reflecting the light back into the fiber. The OS2 fiber patch cord is engineered for low attenuation and performance that exceeds ITU-T G652.D/G657.A1 and IEC60703-2-50 type B1.3/B6.a1 industry standards.
  • LSZH Cable Jacket
    Housed in a Low-Smoke Zero-Halogen (LSZH) flame-retardant jacket, the OS2 fiber cable emits low smoke and toxic fumes when exposed to extreme heat or in the event of a fire. This enables safer cable installations in areas with poor ventilation including some industrial settings, self-contained environments such as trains and aircraft, as well as residential settings where compliance with building codes must be considered. Each OS2 fiber cable is individually tested for insertion loss performance and includes a test report, for guaranteed compatibility and 100% reliability.
StarTech.com 15m (49.2ft) LC to SC (UPC) OS2 Single Mode Simplex Fiber Optic Cable, 9/125µm, Laser Optimized, 40G/100G, Bend Insensitive, Low Insertion Loss - LSZH Fiber Patch Cord (SPSMLCSC-OS2-15M) - patch cable - 15 m - yellow
Patch cable - OS1/OS2
Simplex fibre optic
Type of Fibre Optics
Singlemode
Halogen-free, passive adapter, bi-directional, ceramic ferrule, bend insensitive, low insertion loss, bending radius 10mm, aramid fibre reinforced, up to 100 Gbps, 0.3 dB insertion loss, 55 dB return loss, wavelength of 1260-1625 nm, Coarse Wavelength Division Multiplexing (CWDM) support
Length
15 m
Diameter
2 mm
Core / Cladding Diameter
9 / 125 micron
Connector
LC/UPC single-mode - male
Connector (Second End)
SC/UPC single-mode - male
Yellow
Network Cable Type
Simplex fibre optic
Singlemode
Jacket Material
Low Smoke Zero Halogen (LSZH)
9 / 125 micron
Length
15 m
Diameter
2 mm
Yellow
Connector
WEEE, EMI
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
0.6 cm
Shipping Weight
63.5 g
-20 °C
60 °C
Length: 15m
Colour: Yellow
