StarTech.com 30m LC to SC OS2 Fiber Cable
Quicklinx: HM0MWS00 Mfr#: SMLCSC-OS2-30M
Length: 30m
Colour: Yellow
£42.82 ex VAT
£51.38 inc VAT
OS2 LC to SC Single Mode Duplex Fiber Optic Patch cable facilitates connectivity across 10G networks. It supports Coarse Wavelength Division Multiplexing (CWDM) across an extended wavelength range of 1260-1625nm, improving channel isolation for optimal signal strength over long distances.
  • Compatibility
    This 9/125µm Single Mode fiber cable supports 1260-1625nm laser-optimized sources and is ideal for critical connections between servers, switches, and data center equipment. It is backward compatible with OS1 networks, ensuring a reliable connection in legacy fiber environments.
  • Engineered for Optimal Performance
    Precision-manufactured ceramic ferrules ensure correct fiber alignment to preserve insertion loss below 0.3dB. Ultra Physical Contact (UPC)-polished LC to SC fiber ends greatly improves return loss characteristics over older PC polishing techniques. The Bend Insensitive fiber core is surrounded by a layer of low refractive index material. This material reduces the amount of light that can escape the fiber cable by reflecting the light back into the fiber. The OS2 fiber patch cord is engineered for low attenuation and performance that exceeds ITU-T G652.D/G657.A1 and IEC60703-2-50 type B1.3/B6.a1 industry standards.
  • LSZH Cable Jacket
    Housed in a Low-Smoke Zero-Halogen (LSZH) flame-retardant jacket, the OS2 fiber cable emits low smoke and toxic fumes when exposed to extreme heat or in the event of a fire. This enables safer cable installations in areas with poor ventilation including some industrial settings, self-contained environments such as trains and aircraft, as well as residential settings where compliance with building codes must be considered. Each OS2 fiber cable is individually tested for insertion loss performance and includes a test report, for guaranteed compatibility and 100% reliability.
StarTech.com 30m (98ft) LC to SC (UPC) OS2 Single Mode Duplex Fiber Optic Cable, 9/125µm, Laser Optimized, 10G, Bend Insensitive, Low Insertion Loss - LSZH Fiber Patch Cord (SMLCSC-OS2-30M) - patch cable - 30 m - yellow
Patch cable - OS1/OS2
Duplex fibre optic
Type of Fibre Optics
Singlemode
Halogen-free, passive adapter, bend insensitive, low insertion loss, wavelength of 1260-1625 nm, colour coded connectors, Coarse Wavelength Division Multiplexing (CWDM) support, aramid fibre reinforced, bending radius 10mm, 0.3 dB insertion loss, 55 dB return loss, ceramic ferrule, up to 10 Gbps
Length
30 m
Diameter
2 mm
Core / Cladding Diameter
9 / 125 micron
Connector
2 x LC/UPC single-mode - male
Connector (Second End)
2 x SC/UPC single-mode - male
Yellow
Network Cable Type
Duplex fibre optic
Singlemode
Jacket Material
Low Smoke Zero Halogen (LSZH)
9 / 125 micron
Length
30 m
Diameter
2 mm
Yellow
Connector
EMI, WEEE, RoHS
Shipping Width
20 cm
Shipping Depth
22 cm
Shipping Height
1.5 cm
Shipping Weight
221.2 g
-20 °C
60 °C
Length: 30m
Colour: Yellow
