StarTech.com 30m 100ft Active HDMI Cable
Quicklinx: BQH7WS00 Mfr#: HDMM30MA
Length: 30m
£122.57 ex VAT
£147.08 inc VAT
Connect your HDMI devices, up to 30m away with no signal loss. This active HDMI cable offers a connection distance of up to 100 feet (30 meters) between your HDMI enabled devices. It meets CL2 rating safety requirements, so it's ideal for in-wall cable runs in your home and office installations.
The cable features built-in amplifier circuitry which actively boosts your HDMI signal, with no external power required, which is the perfect solution for longer transmissions without any signal loss.
The HDMI cable is CL2-rated for in-wall installations making them perfect for office or residential cable runs. You can set up your home theater, gaming or audio-video equipment with the cables hidden away safely inside the walls and place your devices as needed throughout your work or living space.
This high-quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high-definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
  • Robust shielding
    The cable features a double shielded design with aluminum mylar foil and braid, offering protection against interference and ensuring consistent performance.
  • High-resolution support
    This HDMI cable supports Ultra HD 4k x 2k resolutions, allowing for picture quality that enhances the viewing experience.
  • Active cable technology
    With signal regeneration capabilities, this active HDMI cable maintains the integrity of your video and audio signals over longer distances.
  • Secure installation
    The CL2 rated jacket allows for safe in-wall mounting, ensuring that the cable can be integrated into your space while meeting building code requirements.
  • Durable connectors
    Gold plated connectors provide reliable connectivity while reducing the risk of corrosion, ensuring longevity.
StarTech.com 30m 100 ft High Speed HDMI Cable M/M - Active - 26AWG - CL2 rated In-wall Installation - Ultra HD 4k x 2k - Active HDMI Cable (HDMM30MA) - HDMI cable - 30 m
Cable
HDMI cable
Double shielded
American Wire Gauge (AWG)
26
Length
30 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
CL2 rated jacket, in wall mounting, active cable (signal regeneration)
Cable Type
HDMI cable
Double shielded
26
Jacket Material
PVC
Shielding Material
Length
30 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
BQH7 StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £7.74
BQH7 StarTech.com 20m (65ft) Active HDMI Cable In Stock £81.23
BQH7 StarTech.com Active Optical HDMI 2.1 Cable 100ft In Stock £217.78
BQH7 StarTech.com Active Optical HDMI 2.1 Cable 30ft In Stock £148.83
BQH7 StarTech.com Active Optical HDMI 2.1 Cable 50ft In Stock £183.62
Length: 30m
