Connect your HDMI devices, up to 30m away with no signal loss. This active HDMI cable offers a connection distance of up to 100 feet (30 meters) between your HDMI enabled devices. It meets CL2 rating safety requirements, so it's ideal for in-wall cable runs in your home and office installations.
The cable features built-in amplifier circuitry which actively boosts your HDMI signal, with no external power required, which is the perfect solution for longer transmissions without any signal loss.
The HDMI cable is CL2-rated for in-wall installations making them perfect for office or residential cable runs. You can set up your home theater, gaming or audio-video equipment with the cables hidden away safely inside the walls and place your devices as needed throughout your work or living space.
This high-quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high-definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
- StarTech.com 30m 100 ft High Speed HDMI Cable M/M - Active - 26AWG - CL2 rated In-wall Installation - Ultra HD 4k x 2k - Active HDMI Cable (HDMM30MA) - HDMI cable - 30 m
- Cable
- HDMI cable
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 26
- Length
- 30 m
- Black
- Connector
- HDMI - male
- Connector (Second End)
- HDMI - male
- CL2 rated jacket, in wall mounting, active cable (signal regeneration)
- 2-year warranty
- Cable Type
- HDMI cable
- Technology
- Double shielded
- 26
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 30 m
- Plated Connector
- Gold
- Black
- Connector
- 19 pin HDMI Type A - male
- Limited warranty - 2 years
StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £8.66 |
StarTech.com 30m 100ft Active HDMI Cable | In Stock | £119.55 |
StarTech.com 20m (65ft) Active HDMI Cable | In Stock | £72.91 |
StarTech.com Active Optical HDMI 2.1 Cable 100ft | In Stock | £218.58 |
StarTech.com Active Optical HDMI 2.1 Cable 50ft | In Stock | £184.31 |
