StarTech.com 30m 100ft Active HDMI Cable
Quicklinx: BQH7WS00 Mfr#: HDMM30MA
Length: 30m
17 in stock
£100.92 ex VAT
£121.10 inc VAT
Connect your HDMI devices, up to 30m away with no signal loss. This active HDMI cable offers a connection distance of up to 100 feet (30 meters) between your HDMI enabled devices. It meets CL2 rating safety requirements, so it's ideal for in-wall cable runs in your home and office installations.
The cable features built-in amplifier circuitry which actively boosts your HDMI signal, with no external power required, which is the perfect solution for longer transmissions without any signal loss.
The HDMI cable is CL2-rated for in-wall installations making them perfect for office or residential cable runs. You can set up your home theater, gaming or audio-video equipment with the cables hidden away safely inside the walls and place your devices as needed throughout your work or living space.
This high-quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high-definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
StarTech.com 30m Active CL2 In-wall High Speed HDMI Cable - M/M - HDMI cable - 30 m
Cable
HDMI cable
Double shielded
American Wire Gauge (AWG)
26
Length
30 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
CL2 rated jacket, in wall mounting, active cable (signal regeneration)
Cable Type
HDMI cable
Double shielded
26
Jacket Material
PVC
Shielding Material
Length
30 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
Length: 30m
Price Range Ex VAT: 100 - 150
