StarTech.com 30in MPC2 CD-ROM Audio Cable - F/F
Quicklinx: 3ZM3WS00 Mfr#: CDAUDIO2
Only best-quality components are used when StarTech.com's expert manufacturing team creates its cabling and this cable is not different. The 30-inch MPC2 CD-ROM audio cable will let you connect a CD-ROM audio output to a sound card. Cables help StarTech.com maintain its tradition of offering top-notch parts and products for the best price possible.
StarTech.com 30in MPC2 CD-ROM Audio Cable - F/F - audio cable - 76.2 cm
Audio cable
Length
76.2 cm
Connector
MPC - female
Connector (Second End)
MPC - female
P/N: PCISOUND4CH, PEXSOUND7CH
Audio cable
Length
76.2 cm
Connector
4 pin MPC - female
4 pin MPC - female
