The StarTech.com 30ft (9.15m) USB-C to HDMI 2.0 Active Optical Cable is a premium solution for extending your HDMI signal over long distances while maintaining high 4K 60Hz video quality. With support for HDR and 4:4:4 Chroma Subsampling, it delivers a vibrant picture that is perfect for streaming, gaming, or any high-definition video application. This cable also supports 7.1 channel Surround Sound, providing an immersive audio experience to accompany your video. Designed with durability in mind, it features EMI protection, strain relief, and a CL3 rated jacket for safe in-wall installation. Whether you're setting up a home theater or a professional AV installation, this cable ensures reliable, high-quality performance.
High-quality connectivity
Experience visual clarity and smoothness with the 4K 60Hz (3840 x 2160) support, making this cable suitable for high-definition video streaming, gaming, and more. The active optical cable (AOC) technology ensures optimal performance over longer distances without signal loss. -
Advanced audiovisual features
This cable supports 10-bit and 8-bit deep color, along with 7.1 channel Surround Sound, providing a rich audiovisual experience. HDR support and 4:4:4 Chroma Subsampling enhance your viewing with vivid colors and deeper blacks. -
Durable and reliable design
Constructed with an outer diameter of 4.5 mm and strain relief, this cable is built for durability. EMI protection and a CL3 rated jacket ensure safe use in wall installations, making it an ideal choice for both home and professional environments.
- StarTech.com 30ft (9.15m) USB-C to HDMI 2.0 Active Optical Cable, 4K 60Hz - HDMI cable - 9.15 m
- Cable
- HDMI cable
- Technology
- Shielded/fibre optic
- Length
- 9.15 m
- Black
- Connectors
- 24 pin USB-C - male (input)
- Connectors (Second End)
- HDMI - male (output) , USB (power only) - male
- OM3
- Active cable, Active Optical Cable (AOC), Unidirectional, 4K60Hz (3840 x 2160) support
- 3-year warranty
- Cable Type
- HDMI cable active, Active Optical Cable (AOC), Unidirectional, 4K60Hz (3840 x 2160) support
- Technology
- Jacket Material
- PVC
- OM3
- Length
- 9.15 m
- CL3 rated jacket, Audio Return Channel (ARC), HDMI CEC support (Consumer Electronics Control), HDR support, support HDR10, 4:4:4 Chroma Subsampling, TMDS support, strain relief, USB powered, 8 bit deep colour, 10 bit deep colour, outer diameter 4.5mm, DisplayPort Alternate Mode support, fibre multimode, 7.1 channel Surround Sound, EMI protection, wide screen support
- Black
Adapters & Converters
- OS Required
- Apple MacOS, Linux, Google Chrome OS, Windows
- Connectors
- 19 pin HDMI Type A - male (output) , 4 pin USB Type A (power only) - male
- FCC, RoHS, WEEE, HDCP 1.2, HDCP 1.4, CL3
- Shipping Width
- 22.4 cm
- Shipping Depth
- 23.4 cm
- Shipping Height
- 3.9 cm
- Shipping Weight
- 427 g
- Limited warranty - 3 years
StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.19 |
StarTech.com 50ft USB-C to HDMI Cable (AOC) | In Stock | £142.75 |
