StarTech.com 30ft USB-C to HDMI Cable (AOC)
Quicklinx: HVLVWS00 Mfr#: 145B-USBC-HDMI4K-AOC
£137.57 ex VAT
£165.08 inc VAT
The StarTech.com 30ft (9.15m) USB-C to HDMI 2.0 Active Optical Cable is a premium solution for extending your HDMI signal over long distances while maintaining high 4K 60Hz video quality. With support for HDR and 4:4:4 Chroma Subsampling, it delivers a vibrant picture that is perfect for streaming, gaming, or any high-definition video application. This cable also supports 7.1 channel Surround Sound, providing an immersive audio experience to accompany your video. Designed with durability in mind, it features EMI protection, strain relief, and a CL3 rated jacket for safe in-wall installation. Whether you're setting up a home theater or a professional AV installation, this cable ensures reliable, high-quality performance.
  • High-quality connectivity
    Experience visual clarity and smoothness with the 4K 60Hz (3840 x 2160) support, making this cable suitable for high-definition video streaming, gaming, and more. The active optical cable (AOC) technology ensures optimal performance over longer distances without signal loss.
  • Advanced audiovisual features
    This cable supports 10-bit and 8-bit deep color, along with 7.1 channel Surround Sound, providing a rich audiovisual experience. HDR support and 4:4:4 Chroma Subsampling enhance your viewing with vivid colors and deeper blacks.
  • Durable and reliable design
    Constructed with an outer diameter of 4.5 mm and strain relief, this cable is built for durability. EMI protection and a CL3 rated jacket ensure safe use in wall installations, making it an ideal choice for both home and professional environments.
StarTech.com 30ft (9.15m) USB-C to HDMI 2.0 Active Optical Cable, 4K 60Hz - HDMI cable - 9.15 m
Cable
HDMI cable
Shielded/fibre optic
Length
9.15 m
Connectors
24 pin USB-C - male (input)
Connectors (Second End)
HDMI - male (output) , USB (power only) - male
OM3
Active cable, Active Optical Cable (AOC), Unidirectional, 4K60Hz (3840 x 2160) support
3-year warranty
Cable Type
HDMI cable active, Active Optical Cable (AOC), Unidirectional, 4K60Hz (3840 x 2160) support
Jacket Material
PVC
OM3
Length
9.15 m
CL3 rated jacket, Audio Return Channel (ARC), HDMI CEC support (Consumer Electronics Control), HDR support, support HDR10, 4:4:4 Chroma Subsampling, TMDS support, strain relief, USB powered, 8 bit deep colour, 10 bit deep colour, outer diameter 4.5mm, DisplayPort Alternate Mode support, fibre multimode, 7.1 channel Surround Sound, EMI protection, wide screen support
Adapters & Converters
Apple MacOS, Linux, Google Chrome OS, Windows
Connectors
19 pin HDMI Type A - male (output) , 4 pin USB Type A (power only) - male
FCC, RoHS, WEEE, HDCP 1.2, HDCP 1.4, CL3
Shipping Width
22.4 cm
Shipping Depth
23.4 cm
Shipping Height
3.9 cm
Shipping Weight
427 g
Limited warranty - 3 years
HVLV StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.19
HVLV StarTech.com 50ft USB-C to HDMI Cable (AOC) In Stock £141.58
