StarTech.com 30cm USB-C Charging Cable - Black
Quicklinx: JFZXWS00 Mfr#: USB2CC30CMNCBR
12 In Stock
£4.64 ex VAT
£5.56 inc VAT
Connect a USB Type-C device to a USB-C wall charger or host computer
Connect a charger or hub to a USB PD-enabled device using this Rugged USB-C Cable, delivering up to 60W Power Delivery and 3A output for fast charging. Clear markings on each connector eliminate confusion, helping you identify the right cable instantly. No more guesswork with lookalike or unmarked USB-C cords.
Rugged and Flexible
The USB-C Charging Cable features a TPE inner jacket with a braided nylon exterior for optimal flexibility and wear protection. The durable nickel-plated connectors are designed for frequent daily use, and are rated to operate beyond 10,000 insertion cycles.
Charge Mobile Devices On The Go
Charge a USB-C device with a USB-C wall charger, car charger, or power bank. The 30cm (1-foot) USB Type-C cable is the ideal length for mobile workstations or in-car use.
Power a Laptop
With up to 3A of output, the USB-C Charger Cord supports up to 60W of Power Delivery to charge a USB-C laptop or fast-charge a tablet or smartphone. To use, connect the cable from a USB-C laptop to a USB-C wall charger.
