Charge a USB Type-C mobile device or transfer files to a USB-A host computer with this high-quality USB-A to Type-C cable. The USB-A to USB-C charger cord supports up to 15W and 3A output for fast charging. It supports USB 2.0 (480Mbps) transfer rates and is suitable for general use. Quality Construction Designed for frequent or daily use, the USB-A to USB-C Charger Cable features a rugged TPE outer jacket for increased wear resistance. Its flexible strain relief and nickel-plated connectors are designed to withstand over 10,000 insertion cycles, enhancing its durability and longevity. Charge Mobile Devices The 30cm (1-foot) USB Charging Cable is the ideal length for charging mobile devices on the go, or minimizing cable clutter on compact desk setups. Facilitating up to 3A of output, the USB-C Charger Cord can fast-charge a smartphone or tablet. To use, connect the cable from a USB-C device to a USB-A wall charger or host device.
Designed for frequent or daily use, the USB-A to USB-C Charger Cable features a rugged TPE outer jacket for increased wear resistance. Its flexible strain relief and nickel-plated connectors are designed to withstand over 10,000 insertion cycles, enhancing its durability and longevity. -
- StarTech.com 1ft (30cm) USB-A to USB-C Charging Cable, Charger Cord - USB-C cable - USB to 24 pin USB-C - 30 cm
- USB-C cable
- Charge and sync, halogen-free, USB Fast Charge (15W), passive cable, 10000 insertions lifespanins, strain relief, EMI protection, 480 Mbps data rate
- Length
- 30 cm
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 24 pin USB-C - male
- Rated Current
- 3 A
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB-C cable
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- Thermoplastic elastomer (TPE)
- American Wire Gauge (AWG)
- 24/32
- Rated Current
- 3 A
- Plated Connector
- Nickel
- Length
- 30 cm
- Outside Diameter
- 3 mm
- Black
- Connector
- USB / USB 2.0, RoHS, halogen-free
- Shipping Width
- 22 cm
- Shipping Depth
- 12.8 cm
- Shipping Height
- 0.5 cm
- Shipping Weight
- 17 g
