Connect USB 3.0 devices up to 10m away, with no signal loss. You don't need to be limited by a standard-sized USB cable. This active USB 3.1 Gen 1 (5 Gbps) cable, better known as a USB 3.0 cable, lets you position your USB Type-B peripherals where you need them, up to 10 meters away from your computer.
Now, you can locate USB devices such as portable hard drives and external video capture devices to make better use of your workspace. This 10-meter (30-foot) cable has a built-in equalizing chip that delivers a reliable connection, with no signal loss, beyond the 3-meter limit of standard USB 3.0 cables.
- StarTech.com 30ft USB 3.0 USB-A to USB-B Cable - M/M - Active - USB Type-A to USB Type-B Cable - USB 3.1 Gen 1 (5 Gbps) Cable (USB3SAB10M) - USB cable - USB Type B to USB Type A - 10 m
- USB cable
- Technology
- Double shielded
- Molded, 5 Gbps data rate
- Length
- 10 m
- Connector
- 9 pin USB Type B - male
- Connector (Second End)
- 9 pin USB Type A - male
- USB 3.0
- Black
- 2-year warranty
- USB cable
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 24/28
- Plated Connector
- Nickel
- Length
- 10 m
- Black
- Connector
- USB 3.0, RoHS
- 2-year warranty
StarTech.com 10m USB 3.0 Active Extension Cable - M/F | In Stock | £116.06 |
StarTech.com 15 ft USB 3.0 A to B Cable M/M | In Stock | £83.46 |
StarTech.com 30 ft USB 3.0 A to B Cable M/M | In Stock | £108.34 |
