StarTech.com 30 ft USB 3.0 A to B Cable M/M
Quicklinx: BJWZWS00 Mfr#: USB3SAB10M
Length: 10m
10 in stock
£114.71 ex VAT
£137.65 inc VAT
Connect USB 3.0 devices up to 10m away, with no signal loss. You don't need to be limited by a standard-sized USB cable. This active USB 3.1 Gen 1 (5 Gbps) cable, better known as a USB 3.0 cable, lets you position your USB Type-B peripherals where you need them, up to 10 meters away from your computer.
Now, you can locate USB devices such as portable hard drives and external video capture devices to make better use of your workspace. This 10-meter (30-foot) cable has a built-in equalizing chip that delivers a reliable connection, with no signal loss, beyond the 3-meter limit of standard USB 3.0 cables.
StarTech.com 30ft USB 3.0 USB-A to USB-B Cable - M/M - Active - USB Type-A to USB Type-B Cable - USB 3.1 Gen 1 (5 Gbps) Cable (USB3SAB10M) - USB cable - USB Type B to USB Type A - 10 m
USB cable
Double shielded
Molded, 5 Gbps data rate
Length
10 m
Connector
9 pin USB Type B - male
Connector (Second End)
9 pin USB Type A - male
USB 3.0
USB cable
Double shielded
American Wire Gauge (AWG)
24/28
Plated Connector
Nickel
Length
10 m
Connector
USB 3.0, RoHS
BJWZ StarTech.com 10m USB 3.0 Active Extension Cable - M/F In Stock £102.06
BJWZ StarTech.com 15 ft USB 3.0 A to B Cable M/M In Stock £80.87
BJWZ StarTech.com 30 ft USB 3.0 A to B Cable M/M In Stock £114.71
Length: 10m
Stock Status: In stock
