StarTech.com's Cat5e UTP Snagless Patch Cables offer reliable Ethernet connections. This 30 ft cable meets or exceeds all Category 5e specifications and features a durable red jacket that simplifies departmental color coding while providing rugged flexibility for network connections.
To ensure long-lasting performance, StarTech.com's high quality Cat5e UTP Snagless Patch Cables feature a snagless design that protects the RJ45 clip from damage and makes the cables less prone to snagging during installation. The cables also feature PVC molded strain relief that prevents the RJ45 connector termination point from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance.
StarTech.com's 30 ft Red Cat5e UTP Snagless Patch Cable is constructed of only top quality materials to ensure optimum durability.
- StarTech.com Cat5e Ethernet Cable - 30 ft - Red- Patch Cable - Snagless Cat5e Cable - Long Network Cable - Ethernet Cord - Cat 5e Cable - 30ft (45PATCH30RD) - patch cable - 9.1 m - red
- Patch cable - CAT 5e
- Technology
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Molded, snagless
- Length
- 9.1 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Red
- 1-year warranty
- Designed For
- P/N: USB31000NDS, USB31000S, USB31000SW
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 28
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Molded, snagless
- Length
- 9.1 m
- Red
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 350 MHz
- 1-year warranty
- Designed For
StarTech.com 19in Cable Management Panel | In Stock | £23.58 |
