StarTech.com 3-Port USB Hub w/ GbE Adapter
Quicklinx: H142WS00 Mfr#: 5G3AGBB-USB-A-HUB
Type: USB Hub
Interface: USB-A
Speed: 5Gbps
Ports: 3
Form Factor: External
12 In Stock
£31.24 ex VAT
£37.48 inc VAT
This USB Hub adds three USB-A 3.2 Gen 1 (5Gbps) ports and one Gigabit Ethernet port to a USB-A enabled desktop or laptop computer. The USB Hub connects to a USB-A port on a computer, using the built-in 1ft. (30cm) host cable. The USB hub is backward compatible with USB 2.0 (480Mbps) devices, ensuring support for a wide range of modern and legacy USB peripherals (e.g., thumb drives, external HDDs/SSDs, HD cameras, mice, keyboards, webcams, and audio headsets).The USB hub is compact in size, facilitating portability when travelling.
  • Gigabit Ethernet
    The USB hub features a Gigabit Ethernet adapter. The Ethernet controller is compatible with the IEEE 802.3u/ab standards and supports Wake-on-LAN (WoL), Jumbo Frames, and V-LAN Tagging. The network adapter enhances laptop network reliability, security, and performance, by utilizing wired 10/100/1000Mbps Ethernet.
  • Bus-Powered with Optional Auxiliary Power
    The USB hub can operate with bus power alone, but features a Micro USB power input that can be connected to a USB power adapter (not included), providing up to 4.5W (5V/0.9A) of power in addition to the 4.5W of bus power from the USB host. This flexibility is ideal for applications where additional power may be required, such as connecting a high-powered USB device, like an external SSD, while using the other ports to connect lower powered devices. For added protection, the USB hub features Overcurrent Protection (OCP). OCP prevents faulty USB peripherals from drawing more power than is safely allocated.
  • Plug and Play
    This device is OS independent, supporting all operating systems, including Windows, macOS, ChromeOS, and Android. The Hub is automatically detected, configured, and installed upon connection to a host computer, such as Apple MacBook, Lenovo X1 Carbon, and Dell XPS. The extra-long built-in 1ft. (30 cm) USB-A host cable enables quick and convenient setup and reduces connector strain on 2-in-1 devices, such as the Surface Pro 7 and laptops on riser stands.
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that is compatible with a wide variety of IT connectivity accessories. The software suite includes: •Text | MAC Address Pass-Through Utility : Improve network security. •Text | USB Event Monitoring Utility : Track and log connected USB devices. •Text | Wi-Fi Auto Switch Utility : Enable users to quickly access faster network speeds via wired LAN.
StarTech.com 3-Port USB Hub with Ethernet, 3x USB-A Ports, Gigabit Ethernet RJ45, USB 3.0 5Gbps, Bus-Powered, USB Hub w/ GbE and 1ft/30cm Long Cable, Portable Laptop USB Hub - USB Expansion Hub w/ Ethernet Adapter (5G3AGBB-USB-A-HUB) - hub - 3 ports
Hub - 3 ports
Subtype
USB
Ports
3 x USB 3.2 Gen 1 + 1 x micro-USB + 1 x 10/100/1000
Performance
Data transfer rate: up to 5 Gbps , Throughput (full duplex): up to 2 Gbps
Jumbo Frame Support
9KB
EEE, flow control, VLAN Tagging, priority encoding, full duplex mode, Auto MDIX, plastic housing, USB powered, WOL, USB overcurrent detection and prevention
IEEE 802.3ab, IEEE 802.3az, IEEE 802.3u, IEEE 802.3x, IEEE 802.1p, IEEE 802.1Q, USB 3.2 Gen 1, USB 3.0, USB 2.0, USB 1.1
5 cm x 42 cm x 1.5 cm
84 g
Space grey
Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 10.11, Apple macOS 10.12 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Apple macOS 13.0, Linux Kernel 4.11.x or later (LTS versions only), Google Chrome OS, Android
Hub - 3 ports
Enclosure Type
Desktop
Subtype
USB
Ports
Performance
Jumbo Frame Support
9KB
X ASIX / VIA VL817 / AX88179A
Status Indicators
Link/activity
3 x USB 3.2 Gen 1 Type A , 1 x 1000Base-T RJ-45 , 1 x micro-USB input Type B
Space grey
1 x USB cable - 30 cm
UASP (USB Attached SCSI Protocol), RoHS, RCM, Plug and Play
5 cm
42 cm
1.5 cm
84 g
Shipping Width
14.2 cm
Shipping Depth
17.2 cm
Shipping Height
3 cm
Shipping Weight
140 g
Limited warranty - 2 years ¦ Technical support - assistance - lifetime
70 °C
0 - 85% RH (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
80 °C
H142 StarTech.com 3-Port USB-C Hub w/Gb Ethernet In Stock £29.50
H142 StarTech.com 4-Port USB Hub 5Gbps, Portable In Stock £26.07
H142 StarTech.com 3-Port USB Hub w/ GbE Adapter In Stock £31.24
H142 StarTech.com 3-Port USB-C Hub w/ Ethernet In Stock £27.36
H142 StarTech.com 4-Port USB-C Hub, 5Gbps In Stock £29.18
Type: USB Hub
Interface: USB-A
Speed: 5Gbps
Ports: 3
