Use this USB C hub to connect three independent HDMI displays to a single USB Type-C port. This MST (Multi-Stream Transport) hub lets you connect three HDMI monitors to your USB-C computer. MST ensures hassle-free setup by natively working on any Windows device that supports DP Alt Mode over USB Type-C, such as models of Dell Precision and Dell XPS laptops and ASUS ROG GL752.
The newest generation of laptops are more portable than ever. Unfortunately, this means you're left with fewer video outputs and a small integrated screen. This MST hub solves these problems by letting you connect three displays to a single USB-C port on your computer, which makes multitasking much easier.
Using the MST hub, you can extend your desktop onto additional monitors and stream independent content to each display. This makes it easier to multitask and increase your productivity, which is perfect for creating an easy-to-dock hot-desk solution with a wireless keyboard and mouse peripheral set.
You can also mirror the same image onto multiple displays for remote viewing applications such as digital signage.
MST technology uses your existing video card to minimize the use of system resources while delivering Ultra HD 4K resolutions. 4K is supported by the latest A/V devices and delivers four times the resolution of 1080p. Plus, because the MST hub can output high-definition 1080p, the MST hub is perfect for high-resolution applications such as graphic design and medical imaging.
Multi-tasking Made Easy
With devices becoming more portable than ever, you can be limited to fewer video outputs and confined to your small integrated screen. This multi-stream transport hub solves that problem by enabling you to connect three displays to your USB-C computer, making multi-tasking much easier. Using this USB-C to HDMI video splitter, you can mirror your display onto additional monitors or stream independent content to each display which makes it the ideal accessory for travel or hot-desking. -
Astonishing Picture Quality
MST technology uses your existing video card to minimize the use of system resources while delivering UHD 4K resolutions for up to two monitors simultaneously. Plus, because the USB-C hub can output HD 1080p on three independent displays, it's perfect for all high-resolution applications such as graphic design and medical imaging. -
Hassle-Free Setup
Multi-stream transport offers an easy setup, by natively working on any Windows device that supports DP Alt Mode over USB Type-C. This USB-C to HDMI adapter is Thunderbolt 3 compatible and offers for plug-and-play installation with no drivers or software required. Additionally, this triple monitor adapter is powered by the USB-C port, meaning no external power cords are necessary. MSTCDP123HD is backed by a StarTech.com 3-year warranty, and free lifetime technical support.
- StarTech.com 3-Port Multi Monitor Adapter, USB-C to 3x HDMI Video Splitter, USB Type-C DP 1.2 Alt Mode to HDMI MST Hub, Dual 4K 30Hz or Triple 1080p, Thunderbolt 3 Compatible, Windows Only - Multi Stream Transport (MSTCDP123HD) - adapter - HDMI / USB - 30 cm
- Cable
- Adapter - HDMI / USB
- Max Output Resolution
- 3840 x 2160 - 30 Hz
- Length
- 30 cm
- Black
- Connector
- 24 pin USB-C - male (input)
- Connector (Second End)
- 3 x HDMI - female (output)
- Displayport 1.2/Thunderbolt 3
- 4K30Hz (3840 x 2160) support
- 3-year warranty
- Designed For
- P/N: TB33A1C
- Cable Type
- Adapter 4K30Hz (3840 x 2160) support
- Interface Supported
- HDMI / USB
- Length
- 30 cm
- DisplayPort Alternate Mode support, Multi Stream Transport (MST), 7.1 channel Surround Sound
- Black
Adapters & Converters
- 3840 x 2160
- Refresh Rate
- 30 Hz
- OS Required
- Microsoft Windows 7 / 8 / 8.1 / 10 (32/64 bits)
- Connector
- 3 x 19 pin HDMI Type A - female (output)
- FCC, RoHS
- 6.5 cm
- 10.5 cm
- 1.5 cm
- 118 g
- Shipping Width
- 15.4 cm
- Shipping Depth
- 24.5 cm
- Shipping Height
- 6.2 cm
- Shipping Weight
- 299 g
- Limited warranty - 3 years
- Designed For
- P/N: TB33A1C
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £9.62 |
StarTech.com USB-C to DisplayPort MST Hub - 2-Port | In Stock | £40.20 |
StarTech.com 1m 3ft Premium HDMI 2.0 Cable | In Stock | £11.32 |
StarTech.com 2m 6ft Premium HDMI 2.0 Cable | In Stock | £15.83 |
StarTech.com 3m 10ft Premium HDMI 2.0 Cable | In Stock | £20.43 |
StarTech.com USB-C to 2x HDMI MST Splitter | In Stock | £32.84 |
StarTech.com USB-C to DP MST Hub - 3-Port | In Stock | £41.68 |
StarTech.com 2m/6.6 ft Premium High Speed HDMI Cable with Ethernet | In Stock | £15.91 |
StarTech.com USB C Dual HDMI MST HUB 4K | In Stock | £34.29 |
StarTech.com 3-Port USB-C MST Hub, 4K 60Hz | In Stock | £47.21 |
StarTech.com USB-C Triple DP MST HUB 4K | In Stock | £55.58 |
