StarTech.com 3-Port USB-C MST Hub, 4K 60Hz
Quicklinx: H1T7WS00 Mfr#: MST14CD123HD
Type: USB Hub
Interface: USB 3.1 Type C
Speed: [N/A]
Ports: 3
Form Factor: External
21 In Stock
£29.54 ex VAT
£35.44 inc VAT
This USB-C to HDMI MST Hub enables a connection to three HDMI monitors, using a DisplayPort Alternate Mode (DP Alt Mode) capable USB-C host device.
  • Multi-Tasking Made Easy
    Configure up to three displays in extended or mirrored mode, using this USB-C to HDMI triple-video adapter. Connecting three independent 4K 60Hz displays creates high-performance extended-display workstations. This encourages increased multi-tasking across your organization, resulting in increased productivity. *Please verify the GPU capabilities and DSC for MST driver support with the OEM of the host device
  • 4K at 60Hz and HDR
    Multi-Stream Transport (MST) technology combines multiple video signals into a single signal/stream. This MST Hub separates the single stream into three independent signals, one for each HDMI enabled display. Support for High Dynamic Range (HDR) offers increased contrast, brightness, colors, and greater luminosity.
  • Hassle-Free Setup
    Windows devices that support DP Alt Mode over USB-C feature native support for MST. This USB-C to HDMI hub is compatible with Thunderbolt 3/4, and USB4 enabled Windows devices. Plug-and-play installation, with no drivers or software required. The 12in (30cm) attached cable provides options for flexible installation configurations, reducing the amount of strain on ports and connectors. Additionally, this triple-monitor splitter is bus-powered, meaning no external power is required. This product is backed for 3-years, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com 3-Port USB-C MST Hub, USB Type-C to 3x HDMI Multi-Monitor Adapter for Laptop, Triple HDMI up to 4K 60Hz w/ DP 1.4 Alt Mode and DSC, HDR, 1ft (30cm) Cable, USB Bus-Powered - Multi-Stream Transport Hub (MST14CD123HD) - video/audio splitter - 3 ports
Video/audio splitter - 3 ports
Subtype
HDMI
Ports
3 x HDMI
USB powered, plastic housing, MST support, HDR support, DisplayPort Alternate mode, triple display support, Synaptics VMM5310 chipset
4.3 cm x 10.5 cm x 1.4 cm
72 g
Space grey
Microsoft Windows 10 / 11
3-year warranty
Enclosure Type
Desktop
Subtype
HDMI
Ports
3 x HDMI
Max Resolution
3840 x 2160 @ 60 Hz
3 x HDMI output
Space grey
1 x USB-C cable - 30 cm
Plug and Play, RoHS, WEEE, RCM, DisplayPort 1.2, DisplayPort 1.4, HDCP 2.2, DSC
4.3 cm
10.5 cm
1.4 cm
72 g
Shipping Width
14.2 cm
Shipping Depth
17 cm
Shipping Height
3 cm
Shipping Weight
124 g
Limited warranty - 3 years , Technical support - assistance - lifetime
0 - 85% RH (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
H1T7 StarTech.com 3ft (1m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI In Stock £16.49
H1T7 StarTech.com 6ft (2m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI In Stock £21.31
H1T7 StarTech.com 10ft Ultra High Speed HDMI 2.1 In Stock £24.71
H1T7 StarTech.com 16ft Ultra High Speed HDMI 2.1 In Stock £40.48
H1T7 StarTech.com 2-Port USB-C MST Hub, 4K 60Hz In Stock £25.08
Type: USB Hub
Speed: [N/A]
Ports: 3
