StarTech.com 3-Port USB-C Hub with SD Card Reader - 10Gbps
Quicklinx: FHJZWS00 Mfr#: HB31C3ASDMB
£47.36 ex VAT
£56.83 inc VAT
Expand the connectivity of your USB-C laptop with this bus-powered 3-Port USB-C hub. It plugs into your laptop's USB Type-C or Thunderbolt 3 port, adding three USB-A ports and an SD card reader, so you can quickly connect more peripherals and devices.
The hub provides direct access to your SD memory cards or microSD cards as an additional medium for data storage and data transfer. Adapter required for microSD cards.
This compact, lightweight USB-Type-C hub is a convenient and portable addition to your laptop accessories. The USB-C cable is built-in, and hub is bus-powered, so it draws its power directly from your computer's USB-C port, with no external power required. That means fewer cables to carry with you when you travel. The hub can draw up to 15 Watts of power from the connected host and operating multiple bus powered devices at one time with the total available power dependent on the connected host.
The extended length attached cable of 9.8" (25 cm) provides more flexibility for longer reach connection requirements and plug and play installation.
With support for USB-A peripherals, this hub is backwards compatible supporting both legacy and new USB devices. You can connect flash drives, video capture devices and external hard drives, with fast data transfer speeds of up to 10Gbps. This USB Type-C hub enhances your productivity, giving you the connections, you need while you work.
  • Versatile connectivity options
    The hub features one USB-C port and three USB 3.1 ports, providing multifunctional support for various devices.
  • Built-in SD card reader
    Equipped with an SD/microSD memory card slot, it allows for quick access to multimedia files without external adapters.
  • Robust build for different environments
    Designed to operate in temperatures ranging from 0°C to 50°C, ensuring sustained functionality in various settings.
  • Ease of use with Plug-and-Play
    No driver installation is necessary, allowing users to connect their devices quickly and easily.
  • USB powered for convenience
    The hub is powered through USB, eliminating the need for an external power source and enhancing portability.
StarTech.com 3 Port 10Gbps USB C Hub with SD Card Reader, 3x USB-A & 1x SD Slot, Portable USB 3.1/3.2 Gen 2 Type C Adapter Hub, Laptop Hub, USB Bus Powered, Thunderbolt 3 Compatible - Windows/macOS/Linux (HB31C3ASDMB) - hub - 3 ports
Hub - 3 ports
Subtype
USB
Ports
1 x USB-C + 3 x USB 3.1
USB powered
USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 2, USB 3.2 Gen 2
20.7 cm x 14.4 cm x 3.8 cm
196 g
Black, space grey
P/N: PEXUSB321C
Hub - 3 ports
Enclosure Type
Desktop
Subtype
USB
Ports
USB powered
X Realtek Semiconductor
1 x USB 3.1 Gen 2 Type C , 3 x USB 3.1 Gen 2 Type A
Expansion Slots
1 (total) / 1 (free) x SD/microSD Memory Card
Black, space grey
1 x USB-C cable - 25 cm
Plug and Play, FCC, RoHS, WEEE, REACH, UASP (USB Attached SCSI Protocol)
20.7 cm
14.4 cm
3.8 cm
196 g
Shipping Width
20.7 cm
Shipping Depth
14.4 cm
Shipping Height
3.8 cm
Shipping Weight
200 g
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
P/N: PEXUSB321C
