StarTech.com 3-Port USB-C Hub with LAN Port - 10Gbps
Quicklinx: FHJXWS00 Mfr#: HB31C2A1CGB
Type: USB
Ports: 3
Data Transfer Rate: 10Gbps
Managed: No
POE: No
Hurry, only 3 left in stock!
£55.93 ex VAT
£67.11 inc VAT
Expand the connectivity of your USB-C laptop with this new generation USB-C Gen 2 hub offering 10Gbps supporting greater bandwidth to connected devices and faster data transfer speeds. This bus-powered 3-Port USB-C hub plugs into the USB Type-C or Thunderbolt 3 port on your device, adding one LAN port, one USB-C port, and two USB-A ports, so you can quickly connect more USB devices.
For faster and more consistent network connections, the USB 3.1 Gen 2 Hub's integrated Gigabit Ethernet port provides wired network access that is fully compatible with IEEE 802.3/u/ab standards. The GbE port also supports Wake-on-LAN (WOL), so you can remotely wake your computer over your network.
This compact, lightweight USB-Type-C hub is a convenient and portable addition to your laptop accessories. The USB-C cable is built-in, and hub is bus-powered, so it draws its power directly from your computer's USB-C port, with no external power required. That means fewer cables to carry with you when you travel. The hub can draw up to 15 Watts of power from the connected host and operating multiple bus powered devices at one time with the total available power dependent on the connected host.
The extended length attached cable of 9.8" (25 cm) provides more flexibility for longer reach connection requirements and plug and play installation.
With ports for both USB-C and USB-A peripherals, this hub is backwards compatible supporting both legacy and new USB devices. You can connect flash drives, video capture devices and external hard drives, with fast data transfer speeds of up to 10Gbps. This USB Type-C hub enhances your productivity, giving you the connections, you need while you work.
  • Gigabit Network Access
    For faster and more consistent network connections, the USB 3.2 Gen 2 Hub's integrated Gigabit Ethernet port provides wired network access that is fully compatible with IEEE 802.3/u/ab standards. The GbE port also supports Wake-on-LAN (WOL), so you can remotely?wake your computer over your network.
  • Convenient Portability and Easy Setup
    This compact, lightweight USB-Type-C hub is a convenient and portable addition to your laptop accessories.? The USB-C cable is built-in, and hub is bus-powered, so it draws its power directly from your computer's USB-C port, with no external power required. That means fewer cables to carry with you when you travel. The hub can draw up to 15 Watts of power from the connected host and operating multiple bus powered devices at one time with the total available power dependent on the connected host. The extended length attached cable?of?9.8" (25 cm) provides more flexibility for longer reach connection requirements and plug and play installation.
  • Connect Both USB-C & USB-A Peripherals
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : To setup and save custom windows layouts. •Text | Mac Address Pass-Through Utility : To improve network security. •Text | USB Event Monitoring Utility : To track and log connected USB devices •Text | Wi-Fi Auto Switch Utility : Enabling users to quickly access faster network speeds via wired LAN.
StarTech.com 3 Port USB C Hub with Gigabit Ethernet RJ45 GbE Port, 2x USB-A, 1x USB-C, SuperSpeed 10Gbps USB 3.1/3.2 Gen 2 Type C Hub Adapter, USB Bus Powered, Aluminum, Works w/TB3 - Windows/macOS/Linux - hub - 3 ports
Hub - 3 ports
Subtype
USB
Ports
1 x USB-C + 2 x USB 3.1 + 1 x 10/100/1000
Auto-uplink (auto MDI/MDI-X), full duplex mode, USB powered, USB Pass-Through
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 2, USB 3.2 Gen 2
4.5 cm x 10.2 cm x 1.4 cm
69 g
Black, space grey
Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012 (32/64-bits), Microsoft Windows Server 2016, Microsoft Windows 7 / 8.1 / 10 (32/64 bits), Ubuntu 14/15/16/17, Microsoft Windows Server 2019, Linux LTS versions only, Android 8.0 (Oreo) or later, Linux Kernel 4.x or later, Google Chrome OS 61 or later, Ubuntu 18, Ubuntu 19, Apple MacOS X 10.10 - 10.15, Apple iPadOS 13.1 or later, Apple macOS 11.0, Apple macOS 12.0, Microsoft Windows 11, Apple macOS 13.0
P/N: PEXUSB321C
Hub - 3 ports
Enclosure Type
Desktop
Subtype
USB
Ports
X Realtek Semiconductor RTS5423 / RTL8153
1 x USB 3.1 Gen 2 Type C , 2 x USB 3.1 Gen 2 Type A , 1 x Gigabit LAN RJ-45
Black, space grey
1 x USB-C cable - 25 cm
Plug and Play, FCC, RoHS, REACH, UASP (USB Attached SCSI Protocol)
4.5 cm
10.2 cm
1.4 cm
69 g
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
P/N: PEXUSB321C
FHJX StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £7.96
FHJX StarTech.com 1m USB 3.1 C to Micro-B Cable In Stock £11.06
FHJX StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £14.29
FHJX StarTech.com USB 3.0 USB-C to USB-A Adapter In Stock £8.05
FHJX StarTech.com 1m USB 3.1 C Cable w/ PD (5A) In Stock £25.63
FHJX StarTech.com 0.5m USB 3.1 C - Micro B Cable In Stock £10.54
FHJX StarTech.com 0.5m USB C Cable - USB 3.1 In Stock £14.73
FHJX StarTech.com 1m 3ft USB 3.1 C to B Cable In Stock £16.24
FHJX StarTech.com 4 -Port USB-C Hub 10 Gbps - 3x USB-A & 1x USB-C In Stock £33.73
FHJX StarTech.com 3-Port USB-C Hub with SD Card Reader - 10Gbps In Stock £48.70
FHJX StarTech.com 3 Port USB C 3.1 Gen 2 Hub with Ethernet Adapter In Stock £66.45
FHJX StarTech.com 4 -Port USB-C™ Hub 10 Gbps - 2x USB-A & 2x USB-C In Stock £43.84
FHJX StarTech.com StarTech.com 2-Port 10Gbps USB-A/USB-C PCIe Card -USB 3.1 In Stock £39.94
FHJX StarTech.com 4 Port USB C Hub - 3 USB-A/1 USB-C (5Gbps USB 3.0) - 11.2" Cable In Stock £47.64
FHJX StarTech.com 4 Port USB C Hub 5Gbps - 4x USB-A - Bus Powered USB 3.0 Type-C Hub - 11in Cable In Stock £28.04
FHJX StarTech.com 4 Port USB C Hub 10Gbps - Metal Industrial USB Type-C Hub In Stock £115.92
FHJX StarTech.com 4 Port USB C Hub 10Gbps In Stock £120.71
FHJX StarTech.com Industrial USB 2.0 Hub In Stock £115.92
FHJX StarTech.com 3-Port USB-C Hub, 2.5GbE, PD In Stock £55.30
FHJX StarTech.com USB-C/USB-A Hub - GbE - RS232 In Stock £66.08
Type: USB
Ports: 3
Managed: No
POE: No
