StarTech.com 3-Port USB-C Hub?with?LAN?Port?-?10 Gbps -?2x USB-A &?1x?USB
Quicklinx: FLXPWS00 Mfr#: HB31C2A1CGS
Type: USB
Ports: 3
48 in stock
£71.42 ex VAT
£85.70 inc VAT
Expand the connectivity of your USB-C laptop with this new generation USB-C 3.1 Gen 2 hub offering 10Gbps supporting greater bus bandwidth to connected devices and faster data transfer speeds. This self-powered 3-Port USB-C hub plugs into the USB Type-C or Thunderbolt 3 port on your device, adding one LAN port, one USB-C port, and two USB-A ports, so you can quickly connect more USB devices.
For faster and more consistent network connections, the USB 3.1 Gen 2 hub's integrated Gigabit Ethernet port provides wired network access that is fully compatible with IEEE 802.3/u/ab standards. The GbE port also supports Wake-on-LAN (WoL), so you can remotely wake your computer over your network.
This compact, lightweight USB-Type-C hub is a convenient and compact addition to your laptop setup. The hub is self-powered and includes a universal power adapter to provide better support of USB devices, such as external storage, that may draw more power.
The USB-C host cable is detached and with an extended length of 3.3' (1 m), it provides more flexibility for longer reach connection requirements and plug and play installation.
For added flexibility and security, the mini hub features mounting holes to work with StarTech.com dock mounts such as SSPMSVESA or SSPMSUDWM.
With ports for both USB-C and USB-A peripherals, this hub is backwards compatible supporting both legacy and new USB devices. It features one always-on USB-A fast charge port which supports two modes of operation: Data transfer and charging when the laptop is connected and on dedicated or hostless charging which provides a higher charging current, when the host is off, on standby, or disconnected.
You can connect video capture devices, portable flash drives, and external hard drives, with fast data transfer speeds of up to 10 Gbps. This 3 port USB Type-C hub enhances your productivity, giving you the connections you need while you work or travel.
StarTech.com 3 Port USB C 3.1 Gen 2 Hub with Ethernet Adapter, 10Gbps USB Type C to 2x USB-A & 1x USB-C Ports, USB Hub w/ BC 1.2 Phone Fast Charging, Superspeed 10Gbps USB C Hub with GbE - Windows/macOS/Linux (HB31C2A1CGS) - hub - 3 ports
Hub - 3 ports
Subtype
USB
Ports
1 x USB-C + 2 x USB 3.1 + 1 x 10/100/1000
Metal housing, USB Attached SCSI Protocol (UASP), USB Pass-Through, Fast Charging Port, Digital Communications Protocol (DCP)
USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 2, USB 3.2 Gen 2
AC 110/240 V 2 A
10 cm x 6 cm x 2.5 cm
87 g
Black, space grey
Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012 (32/64-bits), Microsoft Windows 7 / 8.1 / 10 (32/64 bits), Google Chrome OS 61, Apple MacOS X 10.10 - 10.13, Linux Kernel 4.x LTS, Ubuntu 14.04.x LTS, Ubuntu 16.04.x LTS, Android 8.x
Japan, New Zealand, North America, United Kingdom, Europe
P/N: PEXUSB321C
Hub - 3 ports
Enclosure Type
Desktop
Subtype
USB
Ports
X Realtek Semiconductor
1 x USB 3.1 Gen 2 Type C , 2 x USB 3.1 Gen 2 Type A , 1 x Gigabit LAN RJ-45
External power adapter
Power Provided
DC 12 V
AC 110/240 V
Electric Current Required
2 A
24 Watt
Black, space grey
1 x USB-C cable - 1 m
Plug and Play, FCC, RoHS, WEEE, REACH, UASP (USB Attached SCSI Protocol)
10 cm
6 cm
2.5 cm
87 g
Shipping Width
21.3 cm
Shipping Depth
14.9 cm
Shipping Height
5.1 cm
Shipping Weight
500 g
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
P/N: PEXUSB321C
FLXP StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £9.71
FLXP StarTech.com 1m USB 3.1 C to Micro-B Cable In Stock £10.82
FLXP StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £13.91
FLXP StarTech.com USB 3.0 USB-C to USB-A Adapter In Stock £8.39
FLXP StarTech.com 1m USB 3.1 C Cable w/ PD (5A) In Stock £24.47
FLXP StarTech.com 0.5m USB 3.1 C - Micro B Cable In Stock £9.84
FLXP StarTech.com 0.5m USB C Cable - USB 3.1 In Stock £13.70
FLXP StarTech.com 1m 3ft USB 3.1 C to B Cable In Stock £15.83
FLXP StarTech.com 4 Port USB Adaptor PCI Express USB 3.1 Gen 2 Controller Card - 3xA + 1xC In Stock £78.33
FLXP StarTech.com 4 -Port USB-C Hub 10 Gbps - 3x USB-A & 1x USB-C In Stock £40.26
FLXP StarTech.com 4-Port USB C Hub - USB 3.1 Gen 2 (10Gbps) - 4x USB-A Powered In Stock £60.17
FLXP StarTech.com Docking Station Mount - Wall Mount / Under-Desk Mounting Pla In Stock £17.18
FLXP StarTech.com Docking Station Mount - For StarTech.com Docks / Hubs - VESA In Stock £22.99
FLXP StarTech.com 4 Port USB C Hub - 3 USB-A/1 USB-C (5Gbps USB 3.0) - 11.2" Cable In Stock £38.34
FLXP StarTech.com 4 Port USB C Hub 5Gbps - 4x USB-A - Bus Powered USB 3.0 Type-C Hub - 11in Cable In Stock £24.00
Type: USB
Ports: 3
Stock Status: In stock
