Our checkout area is closed for maintenance, but should be back online soon. We apologise for any inconvenience caused
StarTech.com 3-Port USB-C Hub w/Gb Ethernet
Quicklinx: H139WS00 Mfr#: HB30C3A1GEA2
Type: USB Hub
Interface: USB
Speed: 5Gbps
Ports: 3
Form Factor: External
Hurry, only 2 left in stock!
£29.50 ex VAT
£35.40 inc VAT
This USB-C Hub with Gigabit Ethernet adds three USB-A 3.2 Gen 1 (5Gbps) ports and one Gigabit Ethernet port to a USB-C enabled computer. The bus-powered USB Hub connects to a USB-C port on a laptop computer, using the built-in 1 ft. (30 cm) host cable. This USB hub is compact in size, facilitating portability when travelling.
  • Gigabit Ethernet
    The USB hub features a Gigabit Ethernet adapter. The Ethernet controller is compatible with the IEEE 802.3u/ab standards and supports Wake-on-LAN (WoL), Jumbo Frames, and V-LAN Tagging. The network adapter enhances laptop network reliability, security, and performance, by utilizing wired 10/100/1000Mbps Ethernet.
  • Connect up to Three USB-A Devices
    The 3-port USB 3.2 Gen 1 (5Gbps) Hub adds three USB-A ports by connecting to a single USB-C port. The USB hub is backward compatible with USB 2.0 (480Mbps) devices, ensuring support for a wide range of modern and legacy USB peripherals (e.g., external storage devices, thumb drives, HDDs/SSDs, HD cameras, mice, keyboards, webcams, and audio headsets). The USB Hub is bus-powered. It draws up to 15W of power from the USB-C host computer. Each downstream USB-A port is capable of providing up to 4.5W (5V/0.9A) of power to the connected peripherals. For added protection to connected USB devices, the USB ports feature Overcurrent Protection (OCP). OCP prevents USB peripherals from drawing more power than is safely allocated for the port.
  • Plug and Play
    This device is compatible with all major operating systems, including Windows, macOS, ChromeOS, iPadOS, and Android. The Hub is automatically detected and configured upon connection to a host computer. This ensures automatic installation and setting configuration with any USB-C laptop, including Thunderbolt 3, Thunderbolt 4 and USB4 computers such as Apple MacBook (Intel/M1/M2), Lenovo X1 Carbon and Dell XPS. The built-in extra long 1 ft. (30 cm) USB-C host cable ensures easy setup and reduces connector strain on 2-in-1 devices such as the Surface Pro 7, iPad Pro, HP Elite X2 and laptops on riser stands.
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that is compatible with a wide variety of IT connectivity accessories. The software suite includes: •Text | MAC Address Pass-Through Utility : Improve network security. •Text | USB Event Monitoring Utility : Track and log connected USB devices. •Text | Wi-Fi Auto Switch Utility : Enable users to quickly access faster network speeds via wired LAN.
StarTech.com 3-Port USB-C Hub with Ethernet, 3x USB-A Ports, Gigabit Ethernet, USB 3.0 5Gbps, Bus-Powered, USB Type-C Hub w/ GbE and 1ft/30cm Long Cable, Portable USB-C to USB-A Laptop Hub - USB Expansion Hub (HB30C3A1GEA2) - hub - 3 ports
Hub - 3 ports
Subtype
USB
Ports
3 x SuperSpeed USB 3.0 + 1 x 10/100/1000
Jumbo Frame Support
9KB
Flow control, WOL, full duplex mode, USB powered, plastic housing, priority encoding, OCP support, EEE, VLAN Tagging, Auto MDIX
IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, USB 1.1, USB 2.0, USB 3.0, IEEE 802.3az, USB 3.2 Gen 1
8 cm x 4 cm x 1.5 cm
42 g
Space grey
Android, Google Chrome OS, Apple macOS 10.12, Apple macOS 10.13, Apple macOS 10.14, Apple iPadOS, Apple macOS 10.11, Apple macOS 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Linux Kernel 4.11.x or later (LTS versions only), Apple macOS 13.0
Hub - 3 ports
Enclosure Type
Desktop
Subtype
USB
Ports
Jumbo Frame Support
9KB
X ASIX / VIA VL817 / AX88179A
Status Indicators
Link/activity
3 x USB 3.2 Gen 1 Type A , 1 x 1000Base-T RJ-45
Space grey
1 x USB-C 3.2 Gen 1 cable - 30 cm
Plug and Play, RoHS, RCM, UASP (USB Attached SCSI Protocol), Thunderbolt 3, Thunderbolt 4
8 cm
4 cm
1.5 cm
42 g
Shipping Width
17 cm
Shipping Depth
14.2 cm
Shipping Height
3 cm
Shipping Weight
94 g
Limited warranty - 2 years , Technical support - assistance - lifetime
45 °C
10 - 85% RH
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
H139 StarTech.com 3-Port USB-C Hub, 2.5GbE, PD In Stock £54.63
H139 StarTech.com USB-C/USB-A Hub - GbE - RS232 In Stock £65.26
Type: USB Hub
Interface: USB
Speed: 5Gbps
Ports: 3
