StarTech.com 3 Port USB 3.0 Hub GbE - USB-C - White
Quicklinx: CLVGWS00 Mfr#: HB30C3A1GEA
Type: USB Hub
Interface: USB 3.1 Type C
Speed: 5Gbps
Ports: 3
Form Factor: External
More than 50 In Stock
£25.84 ex VAT
£31.00 inc VAT
Turn a USB Type-C port on your laptop into three USB Type-A ports (5Gbps) and one GbE port. Here's a must-have accessory for your USB-C equipped MacBook Pro, Chromebook or laptop. This USB 3.0 hub merges your USB peripheral and RJ45 network connections into a single combination hub. It gives you two vital connection types, with Ethernet and USB Type-A, which are often missing from modern laptops.
This 3-port USB hub features an easy-to-use USB-C connector. USB Type-C connectors are easier to insert than past generations. They're small and reversible, and you can connect the plug with either side facing up.
If your MacBook or laptop is missing the ports you need, this hub can help. USB 3.0 is also known as USB 3.1 Gen 1. The versatile USB 3.0 hub gives you access to not only your USB peripheral devices but also a wired internet connection. It offers a Gigabit Ethernet port, so you can connect to a network in locations where Wi-Fi is unreliable or unavailable.
The stylish USB hub features an attractive white finish.
The hub features a rugged yet lightweight housing, so there's no need to sacrifice dependability for portability. Its USB-powered design means you don't need to carry a separate power adapter, so you can tuck the USB 3.0 hub neatly into your travel bag.
This hub is perfect for travel, and it takes up minimal space on a desk, so you can use it in hot-desk or BYOD (Bring Your Own Device) environments.
The hub's built-in USB-C cable makes connections easy, and you don't need to carry a separate cable to attach the hub to your laptop.
  • Easily connect to your network and peripherals through USB-C
  • Merges two vital port types into one stylish hub
    If your MacBook or laptop is missing the ports you need, this hub can help. known as USB 3.2 Gen 1. The versatile USB 3.2 Gen 1 hub gives you access to not only your USB peripheral devices but also a wired internet connection. It offers a Gigabit Ethernet port, so you can connect to a network in locations where Wi-Fi is unreliable or unavailable. The stylish USB hub features an attractive white finish.
  • Rugged, portable, and bus powered
    The hub features a rugged yet lightweight housing, so there's no need to sacrifice dependability for portability. Its USB-powered design means you don't need to carry a separate power adapter, so you can tuck the USB 3.2 Gen 1 hub neatly into your travel bag. This hub is perfect for travel, and it takes up minimal space on a desk, so you can use it in hot-desk or BYOD (Bring Your Own Device) environments.
  • Built-in cable eliminates aggravation
    The hub's built-in USB-C cable makes connections easy, and you don't need to carry a separate cable to attach the hub to your laptop. The HB30C3A1GEA is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com 3 Port USB C Hub w/ Gigabit Ethernet – USB Type C to 3 x USB-A – Multi Port USB 3.0 Hub for MacBook Pro (HB30C3A1GEA) - hub - 3 ports
Hub - 3 ports
Subtype
USB
Ports
3 x SuperSpeed USB 3.0 + 1 x 10/100/1000
Jumbo Frame Support
9KB
Full duplex capability, auto-negotiation, VLAN support, WOL, auto-uplink (auto MDI/MDI-X), plastic housing, UASP
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, USB 1.1, USB 2.0, USB 3.0, IEEE 802.3az
4.1 cm x 7.8 cm x 1.5 cm
36 g
White
Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple MacOS X 10.11 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Apple macOS 13.0, Linux Kernel 4.11.x or later (LTS versions only)
Hub - 3 ports
Subtype
USB
Ports
Jumbo Frame Support
9KB
X VIA VL812
3 x USB 3.0 Type A , 1 x 1000Base-T RJ-45 , 1 x USB 3.0 Type C
Internal power supply
White
1 x SuperSpeed USB cable - 9.5 cm
FCC, RoHS, WEEE, RCM
4.1 cm
7.8 cm
1.5 cm
36 g
Shipping Width
14.5 cm
Shipping Depth
17.2 cm
Shipping Height
3.2 cm
Shipping Weight
102 g
45 °C
5 - 90% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
CLVG StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Ethernet Adapter NIC - Aluminum w/ Cable In Stock £39.78
CLVG StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £7.59
CLVG StarTech.com USB-C to Gigabit Adapter In Stock £26.04
CLVG StarTech.com 4 Port USB 3.0 Hub - USB-C Hub In Stock £30.59
CLVG StarTech.com 1m USB 2.0 USB-C to USB-A Cable In Stock £10.31
CLVG StarTech.com 3Pt Portable USB 3.0 Hub + GbE In Stock £34.00
CLVG StarTech.com USB-C to Gigabit Adapter In Stock £36.31
CLVG StarTech.com 3 Port USB 3.0 Hub with USB-C and GbE 3 ports - Desktop In Stock £43.58
CLVG StarTech.com 3 Port USB 3.0 Hub GbE - USB-C - White In Stock £25.84
CLVG StarTech.com 4 Port USB 3.0 C Hub - C to A In Stock £27.64
CLVG StarTech.com 4 Port USB 3.0 C Hub - C to A In Stock £37.25
CLVG StarTech.com 4-Port USB-C Hub - USB 3.1 In Stock £34.22
CLVG StarTech.com 4-Port USB 3.0 Hub with On/Off In Stock £24.24
CLVG StarTech.com 4 Port USB 3.0 Hub USB-C to 4x USB-A In Stock £30.80
CLVG StarTech.com 3-Port USB-C Hub w/Gb Ethernet In Stock £32.78
CLVG StarTech.com 3-Port USB-C Hub, 2.5GbE, PD In Stock £54.63
CLVG StarTech.com USB-C/USB-A Hub - GbE - RS232 In Stock £64.25
Type: USB Hub
Speed: 5Gbps
Ports: 3
