Turn a USB Type-C port on your laptop into three USB Type-A ports (5Gbps) and one GbE port. Here's a must-have accessory for your USB-C equipped MacBook Pro, Chromebook or laptop. This USB 3.0 hub merges your USB peripheral and RJ45 network connections into a single combination hub. It gives you two vital connection types, with Ethernet and USB Type-A, which are often missing from modern laptops.
This 3-port USB hub features an easy-to-use USB-C connector. USB Type-C connectors are easier to insert than past generations. They're small and reversible, and you can connect the plug with either side facing up.
If your MacBook or laptop is missing the ports you need, this hub can help. USB 3.0 is also known as USB 3.1 Gen 1. The versatile USB 3.0 hub gives you access to not only your USB peripheral devices but also a wired internet connection. It offers a Gigabit Ethernet port, so you can connect to a network in locations where Wi-Fi is unreliable or unavailable.
The stylish USB hub features an attractive white finish.
The hub features a rugged yet lightweight housing, so there's no need to sacrifice dependability for portability. Its USB-powered design means you don't need to carry a separate power adapter, so you can tuck the USB 3.0 hub neatly into your travel bag.
This hub is perfect for travel, and it takes up minimal space on a desk, so you can use it in hot-desk or BYOD (Bring Your Own Device) environments.
The hub's built-in USB-C cable makes connections easy, and you don't need to carry a separate cable to attach the hub to your laptop.
Easily connect to your network and peripherals through USB-C
This 3-port USB hub features an easy-to-use USB-C connector. USB Type-C connectors are easier to insert than past generations. They're small and reversible, and you can connect the plug with either side facing up. -
Merges two vital port types into one stylish hub
If your MacBook or laptop is missing the ports you need, this hub can help. USB 3.0 is also known as USB 3.1 Gen 1. The versatile USB 3.0 hub gives you access to not only your USB peripheral devices but also a wired internet connection. It offers a Gigabit Ethernet port, so you can connect to a network in locations where Wi-Fi is unreliable or unavailable. -
Rugged, portable, and bus powered
The hub features a rugged yet lightweight housing, so there's no need to sacrifice dependability for portability. Its USB-powered design means you don't need to carry a separate power adapter, so you can tuck the USB 3.0 hub neatly into your travel bag. -
Built-in cable eliminates aggravation
- StarTech.com 3 Port USB C Hub w/ Gigabit Ethernet – USB Type C to 3 x USB-A – Multi Port USB 3.0 Hub for MacBook Pro (HB30C3A1GEA) - hub - 3 ports
- Hub - 3 ports
- Subtype
- USB
- Ports
- 3 x SuperSpeed USB 3.0 + 1 x 10/100/1000
- Jumbo Frame Support
- 9KB
- Full duplex capability, auto-negotiation, VLAN support, wake on LAN (WOL), auto-uplink (auto MDI/MDI-X), plastic housing, USB Attached SCSI Protocol (UASP)
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, USB 1.1, USB 2.0, USB 3.0, IEEE 802.3az
- 4.1 cm x 7.8 cm x 1.5 cm
- 36 g
- White
- 2-year warranty
- Hub - 3 ports
- Subtype
- USB
- Ports
- 9KB
- Processor
- X VIA VL812
- 3 x USB 3.0 Type A , 1 x 1000Base-T RJ-45 , 1 x USB 3.0 Type C
- Power Device
- Internal power supply
- White
- Cables Included
- 1 x SuperSpeed USB cable - 9.5 cm
- FCC, RoHS, WEEE, RCM
- 4.1 cm
- 7.8 cm
- 1.5 cm
- 36 g
- Shipping Width
- 14.5 cm
- Shipping Depth
- 17.2 cm
- Shipping Height
- 3.2 cm
- Shipping Weight
- 102 g
- Limited warranty - 2 years
- 0 °C
- 45 °C
- 5 - 90% (non-condensing)
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 70 °C
StarTech.com 5 Port Unmanaged Energy-Efficient Gigabit Ethernet Switch | In Stock | £17.16 |
StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Ethernet Adapter NIC - Aluminum w/ Cable | In Stock | £42.38 |
StarTech.com 1m USB 3.1 USB-C to USB-A Cbl | In Stock | £9.82 |
StarTech.com USB-C to Gigabit Adapter | In Stock | £23.48 |
StarTech.com 4 Port USB 3.0 Hub - USB-C Hub | In Stock | £27.51 |
StarTech.com 1m USB 2.0 USB-C to USB-A Cable | In Stock | £8.54 |
StarTech.com 3Pt Portable USB 3.0 Hub + GbE | In Stock | £37.95 |
StarTech.com USB-C to Gigabit Adapter | In Stock | £38.61 |
StarTech.com 3 Port USB 3.0 Hub with USB-C and GbE 3 ports - Desktop | In Stock | £55.57 |
StarTech.com 3 Port USB 3.0 Hub GbE - USB-C - White | In Stock | £40.99 |
StarTech.com 4 Port USB 3.0 C Hub - C to A | In Stock | £31.28 |
StarTech.com 4-Port USB-C Hub - USB 3.1 | In Stock | £40.01 |
StarTech.com 4-Port USB 3.0 Hub with On/Off | In Stock | £27.72 |
StarTech.com 4 Port USB 3.0 Hub USB-C to 4x USB-A | In Stock | £29.86 |
