StarTech.com 3 Port PCIe USB 3.0 Card + GbE
Quicklinx: BCN8WS00 Mfr#: PEXUSB3S3GE
Type: Network / USB adapter
Compatibility: PC
Interface: PCI Express 2.0 x1
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
£37.15 ex VAT
£44.58 inc VAT
Running low on expansion slots? Merge USB 3.0 and GbE into a single PCIe combo card. This PCIe USB 3.0 card couples your peripheral and network connections into a single, scalable solution.
By combining three USB 3.0 ports and one RJ45 port onto a single card, you only need a single PCIe slot for installation, which lets you free up space for other add-ons or upgrades and get more out of your desktop or server.
If you have separate cards for your USB and network connections, this versatile card overcomes the aggravation of running out of PCIe slots while helping to reduce clutter inside your PC.
This dual-purpose card is perfect for building or upgrading your computer. It helps you save money by avoiding the additional costs of purchasing separate USB 3.0 and Gigabit Ethernet adapters.
You can rest assured this card will fit in your small form-factor system, if needed. It features a dual-profile design that makes it easy to install in either standard or low-profile cases.
The combo card makes it easy to connect peripherals such as your external hard drives or mobile devices. Plus, it's backward compatible with USB 2.0 and 1.x, so you won't have to replace all of your existing USB devices.
Functioning as a network adapter, the card delivers wired network access in locations where Wi-Fi is unavailable or unreliable.
Support for advanced features such as jumbo frames and VLAN tagging means you can optimize network traffic as needed.
This high-performance SuperSpeed USB 3.0 adapter card supports data transfer rates up to 5 Gbps and is enhanced with UASP support, which can perform ~70% faster read speed and 40% faster write speed over traditional USB 3.0.
  • Combo-card convenience and cost-savings
    If you have separate cards for your USB and network connections, this versatile card overcomes the aggravation of running out of PCIe slots while helping to reduce clutter inside your PC. This dual-purpose card is perfect for building or upgrading your computer. It helps you save money by avoiding the additional costs of purchasing separate USB 3.0 and Gigabit Ethernet adapters.
  • Flexible install options and legacy device support
    You can rest assured this card will fit in your small form-factor system, if needed. It features a dual-profile design that makes it easy to install in either standard or low-profile cases. The combo card makes it easy to connect peripherals such as your external hard drives or mobile devices. Plus, it's backward compatible with USB 2.0 and 1.x, so you won't have to replace all of your existing USB devices.
  • Gigabit connectivity and network management
    Functioning as a network adapter, the card delivers wired network access in locations where Wi-Fi is unavailable or unreliable. Support for advanced features such as jumbo frames and VLAN tagging means you can optimize network traffic as needed.
  • Effective USB 3.0 performance enhanced by UASP
    This high-performance SuperSpeed USB 3.0 adapter card supports data transfer rates up to 5 Gbps and is enhanced with UASP support.
StarTech.com 3 Port PCI Express USB 3.0 Card + Gigabit Ethernet - network / USB adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 2.0 x1
Ports
USB 3.0 x 3 + 1000Base-T x 1
1.8 cm x 7.7 cm x 12 cm
150 g
USB, GigE, USB 2.0, USB 3.0
Data Transfer Rate
5 Gbps
uPD720201 - Renesas
IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, USB 1.1, USB 2.0, USB 3.0, IEEE 802.3az
Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Linux 2.6.31 or later, Microsoft Windows Server 2012, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Windows 10 (32/64 bits)
PCI Express 2.0 x1
Ports
Wired
USB, Gigabit Ethernet, USB 2.0, SuperSpeed USB 3.0
Data Transfer Rate
5 Gbps
Built-in SATA power connector, USB Attached SCSI Protocol (UASP)
Processor / Memory
uPD720201 - Renesas
3 x USB 3.0 - 9 pin USB Type A (external) , 1 x 1000Base-T - RJ-45 (external)
Low-profile bracket
MTBF
1,920,042 hour(s)
FCC, RoHS
Software Included
Drivers & Utilities
1.8 cm
7.7 cm
12 cm
150 g
5 °C
50 °C
20 - 80%
BCN8 StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £2.95
BCN8 StarTech.com 25 ft Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £7.22
BCN8 StarTech.com 100 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £24.02
BCN8 StarTech.com 10 ft Cat5e Blue Snagless RJ45 UTP Cat 5e Patch Cable - 10ft Patch Cord In Stock £3.21
BCN8 StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter with 3 Port Hub - White In Stock £35.59
BCN8 StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - LP4 Power In Stock £18.53
BCN8 StarTech.com 4 Port USB 3.0 Hub plus 3 Dedicated USB Charging Ports (2 x 1A & 1 x 2A) In Stock £42.07
BCN8 StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - SATA Power In Stock £21.21
BCN8 StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Ethernet Adapter NIC - Aluminum w/ Cable In Stock £35.66
BCN8 StarTech.com 3 Port USB 3.0 Hub plus Combo Fast-Charge Port (2.1A) with Smartphone / Stand - Black In Stock £16.16
BCN8 StarTech.com USB 3.0 Dual 3.5in SATA III Hard Drive RAID Enclosure with Fast Charge USB Hub & UASP In Stock £91.38
BCN8 StarTech.com USB 3.0 IDE / SATA Enclosure In Stock £20.98
BCN8 StarTech.com 7 Port USB 3.0 Hub Desktop In Stock £47.45
BCN8 StarTech.com 7 Port PCIe USB 3.0 Card In Stock £48.98
BCN8 StarTech.com 4 Port PCIe USB 3.0 Card In Stock £25.06
BCN8 StarTech.com 3 Port PCIe USB 3.0 Card + GbE In Stock £37.15
Compatibility: PC
Price Range Ex VAT: 0 - 50
