StarTech.com 3 PORT PCI USB 2.0 CARD
Quicklinx: 4LGCWS00 Mfr#: PCI330USB2
Want to plug into today's most advanced USB peripherals? With speeds up to 40 times faster than USB 1.1, the StarTech.com's PCI330USB2 is your ticket to high-speed action. This card lets you connect up to three USB 2.0 peripherals and enjoy fast data transfer rates of up to 480 Mbits/sec. Plus, backwards compatibility with USB 1.1 means you can continue using your older USB peripherals. The PCI330USB2 is built with an NEC chipset for increased reliability and compatibility with USB devices. Easy plug and play makes installation a breeze, and hot swapping capabilities guarantee convenient, hassle-free connections without rebooting.
StarTech.com 4 Port PCI High Speed USB 2.0 Adapter Card - USB adapter - PCI - 4 ports
USB adapter
Plug-in card
Interface (Bus) Type
PCI
Bus Voltage
Universal (3.3 V & 5.0 V)
2 cm x 12.7 cm x 12 cm
45 g
Ports Qty
4 ports
USB, USB 2.0
Data Transfer Rate
480 Mbps
Apple MacOS X, Microsoft Windows 98SE/2000/ME/XP, Microsoft Windows Vista
P/N: ICUSBAUDIO, ICUSBAUDIO7D, ICUSBAUDIOB
USB adapter - 4 ports
Plug-in card
PCI
Bus Voltage
Wired
USB, USB 2.0
Data Transfer Rate
480 Mbps
3 x USB 2.0 - 4 pin USB Type A (external) , 1 x USB 2.0 - 4 pin USB Type A (internal)
Compatible Slots
1 x PCI
FCC, RoHS
Software Included
Drivers & Utilities
2 cm
12.7 cm
12 cm
45 g
