StarTech.com 3 Port PCI Express 12V PoweredUSB Adapter Card - USB PlusPower
Quicklinx: 76T6WS00 Mfr#: PEX312PUSB
This PCI Express based 12V Powered USB Card allows you to add three Powered USB (USB PlusPower) ports to any standard form-factor sized computer, using an available PCI Express Slot.
Drawing power from either the PCI Express slot or the computer power supply, the powered USB adapter card provides up to 3A of current to each connected device, allowing for up to three Powered USB devices to be installed at the same time.
Plus, the PCI Express Powered USB Adapter card can be connected to the corresponding accessory daughter board PUSBADAP (2 Port Low Profile 12V/24V Powered USB Adapter Card), to create two additional Powered USB ports, but does not require a second PCI Express slot.
StarTech.com 3 Port PCI Express 12V Powered USB Adapter Card USB Plus Power - USB adapter - PCIe - USB 2.0 x 3
USB adapter
Plug-in card
Interface (Bus) Type
PCI Express x1
Ports
USB 2.0 x 3
12 cm x 6.9 cm
200 g
USB, USB 2.0
Data Transfer Rate
480 Mbps
1 x NEC µPD720101GJ
Microsoft Windows 2003, Microsoft Windows 2000 / ME / XP/ Vista
P/N: PUSBDYB24V06, PUSBDYB24V10, PUSBDYB24V03
USB adapter
Plug-in card
PCI Express x1
Ports
USB 2.0 x 3
Wired
USB, USB 2.0
Data Transfer Rate
480 Mbps
Processor / Memory
1 x NEC µPD720101GJ
3 x USB 2.0 - 8 pin USB PlusPower (12 V)
Compatible Slots
1 x PCI Express x1
FCC, RoHS
Software Included
Drivers & Utilities
12 cm
6.9 cm
200 g
Limited warranty - lifetime
StarTech.com 24V to Hosiden+USB B Powered USB Cable
