StarTech.com 3 Port Low Profile PCI 12V PoweredUSB Adapter Card - USB PlusPower
Quicklinx: 5FR7WS00 Mfr#: PCI312PUSBLP
This PCI based Powered USB Adapter Card adds three Powered USB (USB PlusPower) ports to any computer, through an available PCI Slot, and features a low profile design that is ideal for installations in a small form factor computer case. Drawing power from either the PCI slot or the computer power supply, the Powered USB adapter card provides up to 3A of current to each connected device, allowing for up to three Powered USB devices to be installed at a time. Plus, this PCI Powered USB Adapter Card can be connected to StarTech.com's 2 Port 12V/24V Powered USB Adapter Card (PUSBADAP), to create two additional Powered USB ports, without using an extra PCI slot.
StarTech.com 3 Port Low Profile PCI 12V PoweredUSB Adapter Card - USB PlusPower - USB adapter - PCI - USB 2.0 x 3
USB adapter
Plug-in card - low profile
Interface (Bus) Type
PCI
Bus Voltage
Universal (3.3 V & 5.0 V)
Ports
USB 2.0 x 3
8.1 cm x 6.7 cm
200 g
USB, USB 2.0
Data Transfer Rate
480 Mbps
1 x NEC µPD720101GJ
Microsoft Windows 2003, Microsoft Windows 2000 / ME / XP/ Vista
P/N: PUSBDYB24V06, PUSBDYB24V10, PUSBDYB24V03
USB adapter
PCI
Bus Voltage
Ports
USB 2.0 x 3
Wired
USB, USB 2.0
Data Transfer Rate
480 Mbps
Processor / Memory
1 x NEC µPD720101GJ
3 x USB 2.0 - 8 pin USB PlusPower (12 V)
Compatible Slots
1 x PCI - low-profile
FCC, RoHS
Software Included
Drivers & Utilities
8.1 cm
6.7 cm
200 g
Limited warranty - lifetime
StarTech.com 24V to Hosiden+USB B Powered USB Cable
